Help I took the frugality too far |
Thad in AR.
Orange Level Access Joined: 12 Sep 2009 Location: Arkansas Points: 9286 |
Posted: 14 Mar 2023 at 7:01am |
I just built a room in my shop to house our freezers.
It’s insulated and going to have a mouse proof exterior door. I priced 36” steel exterior doors and sticker shock scared me away. I went to a local used store last night and found exactly the door I want with left hand swing and all. They said they would take $30.00 I bought it. This door had something glued to the surface. They used silicon and spread it with a 1/8” notched trowel. I tested a couple spots and it was peeling of very easy. I got it home and hung the door. After I was satisfied with the installation I begun the process of removing the silicon. It doesn’t peel off everywhere as easy as it did in my test spots. Any advice on this? Has it on both sides. Also silicon peelings sure don’t sweep up easily either. Anything soften cured silicon? |
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29672 |
Enamel Reducer. Go to a local body shop, buy what they use.
8070nc
Silver Level Access Joined: 21 Mar 2019 Location: North Carolina Points: 404 |
Ether like some folks use to start engines always released for me
1984 80780
KMAG
Orange Level Access Joined: 26 May 2020 Location: Elizabethtown, Points: 654 |
Brake cleaner softens/destroys most silicone. Get the chorinated version - the less eco friendly the better.
Les Kerf
Orange Level Joined: 08 May 2020 Location: Idaho Points: 634 |
Try some rubbing alcohol, it probably isn't as effective as the harsher chemicals mentioned above but isn't as nasty to work with.
