I-60 Backhoe removal |
WingsofRed
Bronze Level Joined: 12 Mar 2023 Location: Ohio Points: 2 |
Posted: 12 Mar 2023 at 6:39pm |
Has anyone removed the backhoe attachment from an I-60? I don't always need it and would like to use the draw bar on occasion. Plus a valve for the dipper cylinder won't move in one direction and it would be easier to get at with the attachment off.
It looks like it would be fairly simple. Remove a couple of hydraulic lines and then possibly 4 pins holding it to the tractor? Thanks in advance! Jim
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77748 |
WE have a CASE 530 and have done it a couple times... Similar to what your thinking... Park and put the outriggers down... Stretch out the arm a bit and put the bucket on the ground... Pull the 4 pins / bolts out of the arms attaching to tractor .... Use the outriggers to lift a little if you need to get freeplay in the pins.... When all 4 pins are out, shut off the tractor and then remove the two hydraluic lines..... might help to set a block or so under the center section between the outriggers so the body has something to set on if it settles down, or you loose outrigger pressure when removing the hoses.
DonBC
Orange Level Access Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 900 |
Decades ago I use to have a H3 crawler loader/backhoe. I guess they made the hoe easy to dismount because the weight of the hoe on the back of the crawler really affected the performance of loader operations. It was set up on the mount so you could remove or reinstall the hoe in less than 10 minutes. I was working on developing a ski area at the time so the crawler was superior to a tractor when working on the slopes.
Calvin Schmidt
Orange Level Joined: 11 Sep 2009 Location: Ontario Can. Points: 4515 |
Years ago I had an I-60 that I would remove the hoe from. Used the hydraulics to take the slack off the top pins to remove and then used the outriggers to lift the hoe out of the bottom hooks. Drive forward a few inches and set the hoe on a good block. I installed quick couplers to join the hoes together with the smaller one "T"ed in. It's been 45 years so the details may need so field adjustment. Traded for a 715 in 1977 and again for a 715B in 1987. Still have the 715B. Great machine
