D17 diesel generator cover
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: D17 diesel generator cover
    Posted: 05 Mar 2023 at 9:48pm
Mine is missing it, would someone take a picture and provide some measurements of the cover that goes over the generator on series 1 diesel.
Thanks in advance
Rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2023 at 8:18pm
BTT, instead of me guessing a few measurements is all I’m asking for. Or a NOS would be even better. I’m trying to put this 3 bar back as original as possible. Just trying to fill in the blanks. Or a good used part will be fine.
Thanks in advance
Edited by AC720Man - 12 Mar 2023 at 8:30pm
A-C_220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-C_220 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2023 at 11:55am
Are you talking about the brush cover or is there another cover?
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2023 at 12:20pm
this should help a lot .
Edited by Fred in Pa - 13 Mar 2023 at 12:29pm
nonetheless ,still dead.
Jasonw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jasonw Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2023 at 12:28pm
I think he referring to the one pictured photo 3 of this tractor...
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2023 at 2:53pm
What is the purpose of the Genny cover? I ran my series 4 diesel for 25 years without 1. I never knew they existed until I read this post.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2023 at 4:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2023 at 4:17pm
It's for the earlier models with the oil bath air cleaner directly above the generator.  Presumably it's to keep any spilled oil off of the genny.  Not for late models with the dry air cleaner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2023 at 4:20pm
They were on the series 1, when changing the oil bath filter it prevents oil from running down on the generator, belts if someone didn’t take their time and slop oil out of the pan.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2023 at 4:22pm
Now that’s funny we were typing at the same time Myron
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2023 at 5:23pm
Thanks guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2023 at 5:24pm
Thanks guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2023 at 7:30pm
I made a card board version and dropped it off to the machine shop. Just going by the partial picture from my manual. It won’t be original but it will be close enough.
Edited by AC720Man - 16 Mar 2023 at 7:31pm
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2023 at 6:08pm
Did anyone find an original one of these, or be willing to take pics and measurements of one?  I could use one too, mine's gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2023 at 7:27pm
Apparently most were tossed aside but it’s actually a functional part that protects the generator. I didn’t get any response, I hope you do. If not, I will post what I am having made when it’s completed.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2023 at 7:39pm
Sounds good, Robbie, thanks!  Maybe one will turn up on a tractor at a show, and perhaps the owner would be kind enough to let one of us get some measurements.  I believe mine is a '60 model, if I remember correctly.  Would you know if the wide fronts are different across the series of D17's, and between gas and diesel?  My wide front has been a little modified.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2023 at 7:51pm
The guy you got your shroud from didn't have the gen cover?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2023 at 9:57pm
He had already parted out the rest of the tractor and the shroud and grill was all he had left. I’m not sure about the WF, but as far as the power steering ,changes occurred several times over the series.
Edited by AC720Man - 20 Mar 2023 at 9:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2023 at 10:01pm
What’s your serial number Kevin?
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2023 at 10:09pm
I don't remember, I'll check tomorrow and report back, Smile
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 8:00pm
29586
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 8:31pm
You do in fact have a late series 1, 1960.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 8:58pm
My neighbor has an early 17, not sure if it's a diesel though.  I'll stop in and find out for sure, if so, I'll see if i can get some pics and dimensions, Smile
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 8:59pm
Of the gen cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 9:00pm
That would be great! Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 9:04pm
It will have to be a diesel to have one. Gas versions had the air filter at the left rear of the engine.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 9:12pm
Wink, I've only seen it from the road when he has all his Allis's sitting outside on a holiday weekend, I can ask his SIL too.
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2023 at 10:21am
Finally found several of these covers that I had replicated several years ago. They were done from an original. If still looking, let me know 563 357 2615  Can send pictures via text
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2023 at 6:51pm
PM sent
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2023 at 7:48pm
Thanks Bill, I sent you a text
