180 front weights help |
stogel
Bronze Level Joined: 30 Jan 2023 Location: Illinois Points: 2 |
Posted: 30 Jan 2023 at 9:18pm |
Hello all. I’ve recently bought an Allis Chalmers 180 from my wife’s family estate. It was her dad’s tractor and of course, is very sentimental. She wants me to use it periodically to ensure it doesn’t just sit in the shed, but I really need some weight on the front of it to put it to use. I’m very unfamiliar with these tractors and am unsure the best method of adding factory front weights (it’s very important to her that it remains original). Can anyone guide me to a resource for front weights? It does has a very small bolt-on weight on the front. From the little bit of research I have done, it appears as though this is a “starter weight”? Thanks
Orange Level Access Joined: 12 Sep 2009 Points: 20169 |
If it is about 5 inches tall and 2 1/2 inches thick, that is a 75 lb weight and most often there are two of those stacked on top of each other. When there are two, they protrude out flush with the grille shell, for a total of 150 lbs. There is a 250 lb weight that can be used first, as it is 12 inches tall and wraps around the front end and then two 75 lb weights can be stacked on the front of it for a total of 400 lbs. That combo is quite common on 180 tractors. What are you lifting that causes you problems ??
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8303 |
Welcome to the forum. Get yourself some manuals, they have lots of info in there.
Can you put pictures on here.
Edited by Mikez - 30 Jan 2023 at 9:49pm |
Unit3
Orange Level Joined: 17 Oct 2009 Location: NC Iowa Points: 5529 |
Another great place is TractorHouse on the internet. Click on tractors and forget about the horsepower. Click on your brand and model. You want to check out AC’s from 170’s - 220’s. You will see all of the different weights styles and brackets that AC had for them. Welcome.
orangereborn
Orange Level Joined: 12 Sep 2009 Location: NW WI Points: 1422 |
go to >http://brianahart.net/weights.htm...It is also in >> Farm Equipment -Knowledge Base section on this forum...directly below the section you posted from...You will love that 180...We have three of them...And welcome to the forum...Dale
Edited by orangereborn - 31 Jan 2023 at 1:21am |
ILGLEANER
Orange Level Access Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
What part of Illinois are you in ? I am in south central near Effingham. I have a couple starter weights and some of the block smaller weights that go on after the starter. Let me know if l can help.
mruhlig77
Orange Level Joined: 19 Aug 2014 Location: central Indiana Points: 577 |
If you are using front end loader...check for clearances...weight info is on this website under archival tutorials...Mark
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 30637 |
I early on could not find weights so opted to add a loader. Was really light in front with any three point equipment without something up front.
