Checking on tire size
Krazy Karl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Krazy Karl Quote  Post ReplyReply Direct Link To This Post Topic: Checking on tire size
    Posted: 19 Oct 2022 at 8:30pm
I have a d15 with 14.9x26 tires on it. I'm just planning ahead for when I need new tires been surfing the web for good used tires. All I can come up with are 16.9x26. will these work? I know some about tires but get lost. I know that 26in rim think the 14.9 or 16.9 I thought is tire width. But also read the 16.9 is also a taller tire. Just trying to sift through all stuff online to make sure I get what I need. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2022 at 9:00pm
Your tractor was never offered with a 16.9 x 26 tire. You can sure install them, but know that your rims are technically too narrow and your drawbar/PTO will be higher.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2022 at 9:16pm
Karl, you are right that the numbers  14.9 and 16.9 are the tire WIDTH... Also the tire HEIGHT from the bead to the outside of the tread  is determined by the SERIES of tire.. On a truck this can be 55, 60, 70, 75 %... etc...... I think tractor tires are about 85% . meaing when you go from a 14.9 to 16.9 width tire,  ( that is 2 inches) , you get about 85% of that  ( or 1.6 inches on each side or 3- 3.2 inchs DIAMETER )  TALLER tire...... so YES, the WIDTH does effect the HEIGHT.
Edited by steve(ill) - 19 Oct 2022 at 9:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Krazy Karl Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2022 at 10:16pm
Thanks Dr. And Steve
