Need PTO Wood Chipper Advice for D17
Oldwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldwrench Quote  Post ReplyReply Direct Link To This Post Topic: Need PTO Wood Chipper Advice for D17
    Posted: 27 Sep 2022 at 9:33am
We got a fairly heavy (5" max) PTO used wood chipper I will be running on the D17IV. We don't plan to compete with Asplungh or anything clearing telephone lines, but will use it occasionally for wood chips for the garden, etc.  No Fargo stuff either hopefully.  It is an older one made by Pequea Machine in New Holland, PA.  It is well built, but I notice it doesn't have any kind of overrun clutch or anything.  Everything is direct with the PTO.  So once that massive flywheel gets moving, it will be moving for a while, and I'm not too crazy about having that thing directly through the PTO.
I'm thinking I would buy an override PTO clutch and use that to help decouple the chipper from the PTO.  Has anyone had any experience with a chipper like this, and would a regular PTO override device help?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2022 at 9:46am
When you want to shut it down, push in the foot clutch and pull the PTO lever out of gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2022 at 10:44am
I run a 3" chipper on my D15.  When you put your foot on the clutch, it comes to a stop pretty quickly.  I don't think you should need an over running clutch in this case.  They are more handy for mowers while you are moving.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2022 at 5:16pm
I'd at least put a shear bolt or friction clutch on it.  If the irresistible force meets the immoveable object, its the drive line that will take the brunt of it!Wink
estout81 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote estout81 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2022 at 5:58pm
I have a Woodland Mills 6 inch chipper on a D17 without overrunning clutch. The machine has a shear bolt, but never sheared. Works great and the tractor doesn't even know it's back there!
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2022 at 5:50am
Unless you plan on driving the tractor with it running, you shouldn't need an over running clutch.  Those don't offer any sheer protection anyway.  I'd assume the chipper has a slip clutch or sheer bolt.  Just make sure that setup is in god condition.
AaronSEIA
