replacing steering shaft bushing? |
Chad_in_PDX
Topic: replacing steering shaft bushing?Posted: 18 Sep 2022 at 10:32pm |
The upper steering shaft bushing on my 1940 B is badly worn. What is the general process for replacing this bushing? Pain in the but job?
Thanks in advance. Chad
10ptjim
Posted: 18 Sep 2022 at 10:54pm |
take steering wheel off, loosen clamp on steering box for the sleeve, slide sleeve off, will probably have to take off tin for tool box to get sleeve off, knock bushing out on way off, install new one, put back together, not terrible to do, just rebuilt gemmar box on our 38B
Mikez
Posted: 19 Sep 2022 at 8:08am |
Is it bushing 210475
Chad_in_PDX
Posted: 19 Sep 2022 at 8:19am |
Mike, if you are asking me, I’m not sure. I’m making the bushing. 1.375 OD, 0.750” ID. Can’t stomach paying $30 for a little plastic bushing.
Chad |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8736 |
Posted: 19 Sep 2022 at 1:42pm |
Probably need a few choice words to complete the job.....
Joined: 11 Sep 2009 Location: illinois Points: 89196 |
Posted: 19 Sep 2022 at 6:49pm |
Jim, pull the steering wheel first and look down the hole.. I have been able to pick them out or push down 1 inch to get out of the way... New bushing only needs to go into the tube just below the surface so the wheel will fit back on..
Seems like you have to dimple the tube or put glue on the bushing to keep it where you want it ..
