WD 3rd and 4th gear
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Topic: WD 3rd and 4th gear
    Posted: 21 Aug 2022 at 10:39am
As in they are hard to find. 1st,2nd and reverse no problems. But 3 & 4 you have to hold your mouth ju-u-ust right.Maybe hold up on the shifter just a mite to get it to engage. No issues once you're in gear and underway. But what a pain.
'52 WD straight shifter.
Edited by exSW - 21 Aug 2022 at 10:40am
Learning AC...slowly
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2022 at 9:04pm
It is only 70 years old and has been shifted a lot of times. Sounds like a lot of ware In top and gear shift. The gear shift wares the bottom off, ball wares along with socket ball sets In. Slot and pin and pin hole also gets slotted. Slotts in rail slots get worn.             MACK
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2022 at 9:28pm
Thing is, it's tight, not loose going into 3rd or 4th. Not sloppy at all.
Edited by exSW - 21 Aug 2022 at 9:28pm
