FORD TWIN I BEAM ?? |
Post Reply | Page <12 |
Thad in AR.
Orange Level Access Joined: 12 Sep 2009 Location: Arkansas Points: 9273 |
You can replace inner and outer front wheel bearings and races for both sides for $40.00 for quality bearings.
If kept serviced they will last many many years. They can be changed on the side of the road with no special tools. A 4x4 socket is helpful but not necessary. Price wheel bearings for a new half ton 4x4 then see about getting them replaced. Then see about servicing them. Then move on to the axles and cv joints which are similar to a foreign piece of front wheel drive car. |
FREEDGUY
He had his henchmen murder striking workers DUDE !!
FREEDGUY
Thanks for "most" of the replies, yet no one answered WHEN the TIB went away
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77809 |
Look it up on YOU TUBE...
Henry paid his workers $5. ... FIRST TO DO THAT... He setup schools for the workers to finish their HS Education... FIRST TO DO THAT ........... If you wanted to WORK , GET and EDUCATION, MAKE GREAT PAY and FOLLOW THE RULES ... then Henry was your MAN... If you were a FREE LOADING TROUBLE MAKER... you didnt do so good.
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29544 |
1999 First year of Solid Front End FWD F250. Believe was 2001 or 2002 when Coil Front returned and the Twin I went away in F150 and F250 2WD
Never saw you ask WHEN Went AWAY.
Wayne180d
Orange Level Joined: 08 Dec 2015 Location: Gilman, Il Points: 5923 |
I think the other guys are trying to catch Ford and have been for a long time.
KJCHRIS
Orange Level Joined: 21 Dec 2015 Location: WC Iowa Points: 815 |
Ford used the twin I beams from 1965 until 2016 on F250 & 350 2wd.
and I think Mid 90's on F150 2 wd. King pins are not an issue on a pickup or large truck as long as they get greased as scheduled. just like tie rod ends, drag links and ball joints but recently most don't even have zerks in them. At work We did far less front end work on the Fords than on the Chev / GMC and Dodge pickups in our fleet. Were buying on low cost bid; 60 - 75 1/2 ton 2 wd per year and 15 - 20 3/4 & 1 ton per year. They were kept in fleet until over 150K miles. |
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4365 |
You need one with the TIB Freebee. You would not spill so much beer when you chug down the railroad tracks to get to the blocked crossing. Ford had a commercial back when they where new driving on the rails with a big star holding a cup of coffee without spilling a drop.
Chevy had a non solid axle in C 60 trucks in 1960, as one is rusting away out in my junk. It drove good for a old truck, but was told real expensive to rebuild.
Orange Level Access Joined: 12 Sep 2009 Points: 19535 |
In 1996 the F-150's went to a more conventional lower A-arm with a ball joint that wore out. They did this to position the engine lower as I remember.
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7988 |
Them early 60's Chevy 2 tons road like a car....sorta. Torsion bar suspension
Dorix
Orange Level Access Joined: 21 Apr 2020 Location: fox valley Points: 936 |
Some are of the opinion that his body guard Harry Bennet was the one behind that. In any case they didn't murder 6 million people.
FREEDGUY
But BENNET was under the thumb of Ford at that time, and those murdered were AMERICAN workers on AMERICAN soil . There's an episode of "Mysteries Of The Abandoned" on the SC/channel, yours truly Ford bought property for a rubber tree plantation in SA and within 2 years was given up by the FMC
Dorix
I assume your talking the hunger march? Bennet had a lot of influence over Ford so much so his family didn't approve and when Henry died one of the first things they did was fire Bennet. So how much under Fords thumb he was isn't clear. Henry Ford did do a number of good things for his employees. As far as the hunger march it wasn't as simple as Fords security murdering people, I have doubts about how accurate wikpedia and the history channel for that matter but if you type in Ford hunger march it does show quite a lot was going on at the time.
Edited by Dorix - 22 Jun 2022 at 7:07pm |
sparky
Orange Level Access Joined: 13 May 2011 Location: So. Indiana Points: 1460 |
All this past history “Horsesh&&t” over a Twin I Beam? Gotta be kidding me.😫
Les Kerf
Orange Level Joined: 08 May 2020 Location: Idaho Points: 617 |
Back in the late 60's or early 70's I remember seeing a Ford commercial where they had a Twin-I-Beam pickup driving along railroad tracks; there was a metal bar attached to the spindle of the front wheel and a metal bar mounted on the front bumper. There were glass bottles standing in between the railroad ties; the bar mounted on the bumper would just barely pass over the top of the bottles, and the bar mounted on the spindle would break the bottles when it dropped down between the ties. I always wondered who got to clean up the mess |
Thad in AR.
Thanks(1)
Every time I look at a new GM I can’t help but see obamas face and remember that they never actually paid back the tax payers.
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11390 |
The BADGE on the hood should have bummers face on it.....
DaveKamp
Orange Level Access Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5638 |
Apparently you didn't get to the part where he had no high opinion of "Der Fuhrer"...
