Copper head gasket sealer |
NEVER green
Orange Level Access Joined: 28 Feb 2013 Location: MN. Points: 6484 |
Posted: 26 Jan 2022 at 5:39pm |
What do you guys use for copper head gasket sealer? I used Permatex copper sealer and it was gone, except for hints of it directly under head bolts where the most squish was.
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4412 |
The engines that I've had copper head gaskets on, I've used O-rings to seal the water and oil passages and fire rings on top of the sleeves. Nothing on the copper gasket itself.
NEVER green
Yep, fire rings on sleeves, since there are no grooves for o-rings, dont they get smashed down to nothing?
bsallis180
Silver Level Joined: 29 Jul 2013 Location: Pennsylvania Points: 207 |
I have used coper coat at the most and that’s it. Chances of it seeping a liquid are high
PaulB
The holes in my copper gaskets are large enough that the O-ring set inside of the gasket and when using a .090 gasket with .125 O-rings they squash down to .090
Orange Level Access Joined: 12 Sep 2009 Points: 19517 |
Hylomar rubbed all over the copper gasket on both sides is about all you can do.
NEVER green
Yep duh, I guess I had it in my head about the pushrod holes, close to the edge of block, hate leaks.
NEVER green
Sigh, hate leaks.
d17brown
Orange Level Joined: 11 Sep 2009 Location: farley iowa Points: 1668 |
3m Black urethane winsheild sealer
phil
NEVER green
Have you used this, if so do you have to pry head off because its good and sticky???
Robacpuller
Silver Level Joined: 07 Apr 2016 Location: Wisconsin Points: 247 |
Defiantlyput o ring on sleave, I make my sleaves with o-ring.
Robacpuller
I TURN o ring right on top. .015
OldAC
Bronze Level Joined: 01 Feb 2018 Location: Rural Michigan Points: 168 |
I've always done the old trick of aluminum paint on headgaskets. I honestly think it prevents leakage better then copper coat - taken apart many things with copper coat that weeped - clean it up and use aluminum engine paint on the used gasket, put it back together and no issues.
