Fuel Primer rebuild kit
jeffgarc12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffgarc12 Quote  Post ReplyReply Direct Link To This Post Topic: Fuel Primer rebuild kit
    Posted: 24 Jan 2022 at 12:03pm
I have a 1967 190xt that is leaking fuel on the fuel primer valve is there a good rebuild kit that would work for both the pump valve and the primer pump itself
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2022 at 3:30pm
74063231 is the agco part number you local dealer may even stock one
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2022 at 5:43pm
AC dealer here refused to sell the kit and thought he would sell me the whole pump at $150.!--well it pizzed me off so I went next door to his store to napa and bought an electric pump for less than $50. and its still on there and works 100 times better than that silly hand thingy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2022 at 9:54pm
I don't understand why you need a pump on there.  The primer is only used when changing a fuel filter or opening up the system.  Under normal conditions, how often would that be needed?
My 190XT didn't even have a primer or electric pump on it when I bought it and the fuel system worked fine - almost the only thing on the tractor that did work!  I pump a primer on the tractor when I restored it and it did its job to push fuel into the system.
