WTB 210/220 front engine plate |
Author | |||||||||||||||
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4767 |
Posted: 27 Nov 2021 at 4:15pm |
Looking for a front engine plate for a 210/220 in good shape. Prefer a stock original one, but will consider one that's been modified for different pump or? I already have other plates, just need one specifically for a 210/220. Thanks! PM here is best.
Sponsored Links | |||||||||||||||
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7981 |
Probably getting scarce?
pirlbeck
Silver Level Joined: 01 Dec 2009 Location: West Central IA Points: 221 |
Is 74027638 the part number? This is the plate that goes between the block and the timing cover and has the flanges on both side for the 2 bolts on each side that bolt to the side frames and support the front of the engine.
These places all show at least one. Rock Valley Tractor Parts
All States AG Parts, Inc - Downing, WI
Mike's Equipment CO.
800-451-5240 Myerstown, PA 17067 |
injpumpEd
Thanks, just wanted to check with our members first, I know they are around. That is the part and part number. An original one won't have the 7, just will be marked 4027638. Thanks!
d17brown
Orange Level Joined: 11 Sep 2009 Location: farley iowa Points: 1668 |
I think I have one
phil
Calvin Schmidt
Orange Level Joined: 11 Sep 2009 Location: Ontario Can. Points: 4515 |
This is what I did to install a "On Highway" engine into a 220. Luckily had a cover plate to install the hydraulic pump
injpumpEd
I already know how to make others work. I am needing an original one to mock up new frame rails, and want the same as what I currently have on my engine, as I don't plan on tearing the engine down once my new frame is built. I have a lot of work into this front plate to fit my P pump, so would like to make the new frame accommodate my engine as it sits. Phil is so close, and I'm currently working on a fuel system for him, so that is the kind of response I was looking for. It is different than the D21. Thanks everyone!
Edited by injpumpEd - 29 Nov 2021 at 5:08pm |
