Allis CA Seat Spring and Shock
ACCA52 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACCA52 Quote  Post ReplyReply Direct Link To This Post Topic: Allis CA Seat Spring and Shock
    Posted: 04 Oct 2021 at 7:41pm
Wanted to share my findings that may help other big guys. I weight 350lbs and the CA seat spring was just too soft. after experimentation i found Monroe shock 555002, Summit Racing 2.5id 12inch unspring length coil over 110lb spring are a good combination. the original spring caps were too small for the spring so i heavily modified some qa1 aluminum flat spring caps to work, but probably would have been better off making something out of steel. Originally i tried 175lb spring but it was way too stiff, did not compress at all with me in the seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2021 at 6:56am
If you have a CA operators manual, it shows the 2 positions for the stock seat shock/spring mount for light/heavy operators, however I think it is fair to say the 350Lbs is an overload for the stock parts.
Dale (Stonelick) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale (Stonelick) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2021 at 5:15pm
I installed a Harley shock on my CA.  Bought a new pair in the box off CL for $20 - Progressive Suspension 412-4037C 412 Series (Chrome) Harley 11.0".  Had to modify the top and bottom mounting bolts a little.  Seems to work well for me, but don't weigh that much.
1951 CA - 1944 C - 1949 B - Kubota M6800
This page was generated in 0.088 seconds.
