D17 Series IV hand clutch oil leak |
Spang89
Bronze Level Joined: 10 Aug 2021 Location: New Richmond WI Points: 5 |
Posted: 20 Sep 2021 at 8:27pm |
Hi guys, I have fluid coming out of the hand clutch. I understand there is an O-Ring that keeps the oil in. Anyone know where to find one to replace or is it a common size ?
DSeries4
AGCO has them. You will also need a gadsket for the access panel beside it. Remember to replace the O rings on each end of the shaft.
Brian Jasper co. Ia
If you’re talking about the hand clutch lever, they aren’t hard to replace. The early ones are simple, you pull the side cover, loosen the set screw on the cross shaft and then can slide it each way to get at the o rings. I’m pretty sure on the later ones they have a key in the shaft that will fall out if you slide the shaft too far. You can probably match the o rings up from one of those assortments, otherwise Agco can get them.
