Western fire smoke - poor tv signals? |
AC7060IL
Orange Level Joined: 19 Aug 2012 Location: central IL Points: 3212 |
Posted: 28 Jul 2021 at 8:20pm |
Is there any correlation to our tv signal being poor because of our air being smoke filled from the western wildfires?
Olympic channel comes & goes. Seems worse at around 3pm & later after 8pm. |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78053 |
Im on DISH... No problems noted unless there is a heavy rain storm SWest of us.... Satellite is basically over Texas.
Hubert (Ga)engine7
Orange Level Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6142 |
Smoke/haze can affect satellite tv signal somewhat. A hard rainstorm will knock ours out completely. But I am not sure about at antenna (over the air) signal. I have the antenna set up at the farm and it goes out for no apparent reason but affects mostly the higher frequency channels. I suspect it may be interference from some other source.
shameless dude
i think it has affected ours
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4370 |
We did not have trouble last year cover by smoke for 3 weeks. Had grandkids for most of a week in there, TV worked or they and grandma would of all been screaming.
Computer is satellite feed here and it was a bit slow but did work. Glad to be able the share the Fruits of having Fruits and Nuts running the west today. The biggest fire in Calyforny was started by lighting on July 4. Burned for 10 days and was less than a 100 acres. Part of the new let "Nature Do its Thing", school of management. But then it got to the has not burned in a 100 years area stuff, and off to the races. All the fire fighting agency's put out every spark for close to a 100 years in the forests of the west. Finally decided better to burn it on there time than as wildfires. Now the Nature Knows Best groups got together with the save the World from Mankind idots still cannot do semi controlled burns in wetter times of the year. No end to the mistakes of the past in sight yet. |
Tad Wicks
Orange Level Joined: 27 Mar 2011 Location: Shandon, CA Points: 2160 |
Shameless, mine too, I just blamed it on old age and I am not talk'n about the TV set
GSTROM99
Silver Level Joined: 12 Dec 2020 Location: Greene, IA Points: 228 |
Weather forecast included "smoke" and I was wondering where it's from. Pretty hazy here. It hasn't affected my fiber optic signal . |
DaveKamp
Orange Level Access Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5644 |
Smoke in the atmosphere WILL affect VHF and UHF (over-the-air TV, amongst many other things), and it IS affecting it. It can both suppress, as well as enhance propogation. With today's 'digital', either enhancement or suppression (which CAN be BOTH) can result in poor reception simply because some OTHER signal is being transmitted in same frequency. Smoke can also accumulate on your antenna's elements and feedpoint connections, causing it t develop shorts, or additional capaciity, hence, serious losses in performance.
GSTROM99
We're finally getting some much needed rain here today, which should help clear some of this off. |
