Ford question |
HD6GTOM
Posted: 30 Jun 2021 at 7:07pm |
Ok guys. I been working on trucks/cars since the 1960's. Son tried to help his neighbor out buy buying his 1994 F150. Short wheelbase, 5.0 motor 4 speed. You start it up. Not moving or moving. No dash lights/warning lights come on but there is a constant beeping sound comming from under the dash. Any ideas? Never heard or seen it before.
Edited by HD6GTOM - 30 Jun 2021 at 8:53pm |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78097 |
there is a separate fuse for the dash lights/ warning lights... might check that..... if the fuse is OK, the dash lights come on with the head light switch / dimmer switch..
ding , ding, ding when the door is open... Is that the beep ? Door switch might be STUCK or broken.. spray with WD40.
Edited by steve(ill) - 30 Jun 2021 at 7:22pm |
dee_veloper
Orange Level Joined: 12 Apr 2021 Location: USA Points: 1168 |
Likely an air bag sensor. Check for computer codes.
Don't confuse my personality with my attitude.
My personality is who I am. My attitude depends on who you are. |
do you have an Air Bag Light on the dash ( over by radio) ? If the BULB burns out, you will get an alarm that tells you to replace the BULB.
Edited by steve(ill) - 30 Jun 2021 at 7:28pm |
Hubert (Ga)engine7
Orange Level Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6142 |
1987's did not have air bags. The only thing stock that should beep is the headlights left on when the key is removed and the door opened or the key left in the ignition when the engine is off and the door opened. I would suspect the headlight switch but that should not affect the warning lights. That 5.0 and the 4spd (3spd w/overdrive) is a great combination.
HD6GTOM
Guys my apologies. Its a 1994 5.0, 4speed with overdrive. The hydraulic clutch is low on fluid and I can't find my brake fluid.
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21587 |
my vote's for the driver's door switch. my '97 did that ding-ding-thing, blew compressed air ,then some wd40, been fine ever since...til tomorrow, right ?
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4429 |
I had a problem with one of my trucks with the door switch. My dome light stayed on all the time, which was pretty annoying at night.
LouSWPA
Orange Level Access Joined: 11 Sep 2009 Location: Clinton, Pa Points: 24033 |
I am still confident of this;
Brian Jasper co. Ia
Air Bag warning light is burned out. Pull the cluster and replace the bulb.
