D17 brake adjustment?
Hunt4Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Topic: D17 brake adjustment?
    Posted: 08 Apr 2021 at 6:26pm
brakes take a long push on pedal to engage, also seams maxed out on brake lock position...
Brakes work ok but won't hold on a small incline with brake lock? ( Can I adjust brakes and hold lock lever tighter?)
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 6:36pm
What series of 17 are we dealing with here?
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 7:13pm
Series 1
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 7:36pm
Be very careful that you don't twist the adjusting rod off when you are trying to turn it. I hope you have better luck getting them to turn, than I did.
Edited by WF owner - 08 Apr 2021 at 7:37pm
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 9:17pm
Brake adjustment for early D17's is done under the brake covers, not by turning threaded brake rods (that's the method for newer D17's with the band/disc style of brakes). In a nutshell, you tighten the big nut you see under the brake housing cover to pull the bands closer to the drum.  And you use the bolt at the back of the brake housing to equalize front and rear halves of the bands.  The proper procedure is listed in the service manual.  I can't recall of the details though so be sure to read the procedure or see if someone else will chime in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2021 at 5:59am
Hmm, I'll have to look and see if I can see it and get to it... Maybe spray a few times with some oil first
