cook shack walls |
shameless dude
Posted: 15 Mar 2021 at 11:47pm |
gonna put laminate wood flooring up on the walls of my cook shack to "pretty" it up some. any tips or tricks on doing this? the old lady.....oooops....i mean the loving wife bought me a BOSCH chop saw a couple years ago, i notice that it can't be set at a straight cut (90 degrees), WTF? have tried numerous things to get it to saw the 90 degree setting and it just won't hold any settings. i may hafta go buy a new slider chop saw to do this. PfffffT!
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3153 |
Maybe hang it on the bias or a herringbone pattern?
Is there a stop on the miter saw you are not seeing? Hard to believe a new saw can't at least square. Specially Bosch. |
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21526 |
'some adjustment required'....there 'should' be a section in the manual to SQUARE the saw....funny really, the 'contractors' mitresaw is 'preset at 89*'...any wonder WHY he always has a tube of caulking for crown molding corner joinery ?????
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77930 |
flooring is made with a tongue and groove type install. Most is not nailed to the floor.
When putting on the wall, i like to get a box of 2 inch finish nails. Put the first row of board down with the TONGUE up and drill hole/ install nail thru the FACE of the board an inch below the tongue... Now take the second board and set on top, pushing the groove over the tongue of the first... then drill and the FACE of the second board and install finish nail into the stud..... You dont really see the small nail heads. Most blend into the board finish.... This is a good way to install flooring on the wall.
Strokendiesel002
Silver Level Joined: 04 Apr 2019 Location: 53158 Points: 252 |
Pretty slick Steve!
shameless dude
thanks Steve! these boards are not very thick...a 1/4 inch maybe. i bought a air brad nailer to do this, i gotta practice to get the right whammy on the nails yet. i can't find any more adjustments on that blamed saw! may hafta drill a hole and put a screw(s) in it. was bought on sale so couldn't take it back, the company is no help. i'll still use it for other things....like cutting smoker wood!
HD6GTOM
I have one of the older saws. I think My 90° setting is on the back of the saw. I'll try to remember to look tomorrow. I've got several deliveries to fill and make tomorrow, hope I remember to look.
yea shammers... 1/4 inch thick is about right.. Most of them "boards" are like masonite with epoxy imbedded in them... My "nail gun" is my left hand and it dont drive nails thru that hard board without bending 50% of them... Practice on a scrap piece and see if your gun will shoot a dozen nails into the board and SEAT them............ thats why i need the drill.
john(MI)
Whenever I bought that stuff they always told me that you have to put that matting behind it so don't forget that!
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11399 |
I don't see why you would have to do that for a wall.
Thad in AR.
Orange Level Access Joined: 12 Sep 2009 Location: Arkansas Points: 9276 |
Is the saw off on the bevel or angle?
felt or foam mat is for cushion and eliminate noise ( scraping) when installed on the FLOOR.
Lars(wi)
Orange Level Access Joined: 14 Sep 2009 Location: Permian Basin Points: 6670 |
Shameless, arnt ya gonna wait till after the move to upgrade the kitchen?
shameless dude
Thad...like i wanna true up and end of a board that broke....bevel? i can get a 90 degree cut on the up/down cut. Lars...if i gotta move, it's going with me, just gotta slide it off the deck onto a trailer/truck. a flatbed tow truck will haul it. john/Steve...there is a piece of foam glued to the bottom of each piece. i see where it says to put glue on the back side, but it would be glued to plastic, and i'm afraid expansion and contraction would make the wall wavey? plus melt the plastic.
tomNE
Orange Level Joined: 13 Sep 2009 Location: dorchester, ne Points: 1216 |
the better quality of the matting, is something i'd recommend. i put in the cheap stuff and ran out. the installer had some better stuff on his truck, we finished with it. after we finished i noticed the difference right away!
shameless dude
i thought about that bevel thing all day, i've never used that term before, and i even took shop in school! guess i musta missed that part! we always called it angles no matter which way the boards were cut! so anyways...when i lay a board down flat on the saw table and want to cut it in any length i just pull the saw down and cut it, but it isn't a true 90 degree cut. PffffT! i may hafta go gits me a slider saw. double PfffffT! Tom...you mean the foam backing on the boards?
Thad in AR.
Say you’re cutting a 1x6 off square. You lay it down flat like you say.
Is the 6” wide cut out of square or is the 1” cut out of square? |
shameless dude
the 6 inch
Thad in AR.
Ok Shameless that’s the angle. The fence and the positive stops control the squareness of that cut. Most saws have slotted holes in the fence for adjustment.
I once had a Mikita slider that quit cutting square. The pin that goes in the positive stop mysteriously got bent. Replaced it and all was fine. The saw should have a knob to tighten between stops to hold it in place. You can also use this feature if necessary. |
unplug saw.. first get a KNOWN good 'square' square...... 2nd, lightly unscrew the screws holding the left 'fence' on the saw, so fence can move around a bit. 3rd lower and lock blade down, place square against blade 4th move fence so that it touches the square. 5th tighten the fence screws, recheck that fence IS square to blade. plugin saw, cut a board at 45*. flip and make a 'corner', check with square. if setup right, it'll be a 90* corner and fir the square exactly. If not, do it again. One trick I learned was to put TWO flat washers under the screws. That was the screw turns and doesn't want to twist/pull the fence. When left fence is square, raise saw, loosen right fence, place level between fences, moce right fence to be flush with level( level is good straight edge), tighten screws, done |
shameless dude
thanks...i'll look it over again. the screw handle in front won't hold it.
Ted J
Orange Level Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18727 |
Jay's got it. All you need is a GOOD square, follow his steps and bingo, you've got it! Have you considered putting sheet rock up first? That'll take care of the waviness.
shameless dude
i HATE sheet rock! this laminate flooring is good looking and should accent the walls really nice. when we finish with the cood shack, hopefully we have enough left over to do one wall in our dining room....to cover the "sheet rock"! if/when we ever build a new house, there won't be any of that drywall chit in it!
Kansas99
Orange Level Access Joined: 26 Feb 2015 Location: W Kansas Points: 4808 |
Tell us how you really feel about sheet rock. I don't like the crap either, finishing a basement room now, bought some cedar fence pickets on sale for the ceiling and interior walls, the outer concrete walls are painted so I guess that's my dry wall. I will say sheet rock would have been cheaper but pi$$ on that! ruff cut cedar even makes me look like a good carpenter.
"LET"S GO BRANDON!!"
Ted J
Thanks(1)
You guys,,, I just said to use sheet rock so he wouldn't have that wavy effect in the walls. It's great for that kind of thing and also deadens the sound, so you can play your stereo just about as loud as you want. Start with Patsy Cline, Charlie Pride, Faron Young, Johnny Cash, Eddie Arnold, George, Loretta, Tammy, Connie, Waylon, Willie, Merle, Conway,,,,,,you gits the idee..... Oh yeah, you gotta have sum beer for visitors,,, and sum snack food... Git er ready buddy!!
