steel building homes |
Post Reply | Page 12> |
Thad in AR.
Orange Level Access Joined: 12 Sep 2009 Location: Arkansas Points: 9291 |
Posted: 29 Jun 2022 at 5:50am |
We’ve built a couple homes with radiant heat on the subfloor.
The subfloor is 1 1/4” thick. It has a groove ringing through it and a thin aluminum sheet covering the entire sheet and pressed down in the grooves. You send the company your building plan and they make the subfloor to fit your plan. Each piece has to go in the correct spot. As the water warms the aluminum sheet it transfers the heat between the water lines. Last one we did was about 2010 or so. $225.00 per sheet for that subfloor. |
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29705 |
Is one belongs to Stone Hill Winery, sits a few hundred feet from Hermann USPS office, looks as made similar to old Gas Station Panels but all are fit well, even the roof is steel.
ac hunter
Orange Level Joined: 05 Jan 2011 Location: OHIO Points: 948 |
Speaking of steel buildings, does anyone remember Lustron that made enameled steel panels after WWII? They were, as I remember, based in Columbus, Ohio on 5th Avenue in part of the old Curtiss - Wright aircraft factory and supplied material for White Castle Hamburger buildings, some gas stations and houses. There are still a few of the homes around here. Steel houses are not a new invention.
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2218 |
Heated floors are the cats meow in any building!!!
fixer1958
The shop I work at has heated floors. Make your feet sweat at 10 degrees.
It's comfortable. Gets cold when a dumbass doesn't shut the fking door but otherwise, it's good.
Get Concrete Warm over an insulated barrier and it will REMAIN Warm with the Doors Opened then closed.
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4436 |
For any new construction I would absolutely go with water heat in the floor. I first saw it done back in the early 60s (it was the new firehouse being built) no matter what the weather was as soon as the bay doors came down it was warm inside again.
With the current lumber prices Red Iron structure buildings are going up all around our area, most as Bardominiums where the House is at one end and the rest is barn/workshop/storage.
Sugarmaker
Not sure where Tom ended up with his steel building/ home? I am very happy with my wooden shop building that I think could pretty easily be a home also. I like steel too. But in my case I have other buildings close by and wanted a different look. So mine is a blend of post and beam construction, OSB and house wrap, vinyl and hemlock exterior and shingle roof. All the things Tom is not looking for. But sometimes a different perspective can help us to make decisions about our own projects. I am actyally doing a lot of steel on the inside of the shop. And as I do that I am becoming more comfortable with working with that material too.
Hope Ambassaduss builds a nice home for their grandfather too! Regards, Chris |
Ambassaduss
Bronze Level Joined: 24 Mar 2021 Location: Austin Points: 2 |
I understand you; my grandfather says the same thing. He was born and raised in the village; his parents had a farm and land. But by chance, he stayed after studies to work in the city, met my grandmother. They got married, bought an apartment. They went on vacation to the village while grandpa's parents were still alive. But after they died, his brothers insisted on selling the house and splitting the money. He often says now how sorry he is that he didn't buy a home in the suburbs instead of a city apartment. My parents and I are worried about him, and we decided to build him a small house outside the city with our everyday savings. There is an old abandoned cottage on the property we bought, and we would like to consult with London Refurb if it is possible to restore it.
Edited by Ambassaduss - 06 May 2021 at 3:28am |
shameless dude
there is a neighbor that just put up his pole barn house, from Google Earth it appears just a regular rectangler building...prolly 50x80 in size. they took out a permit for it for $246,000. it's a Cleary building, i see lots of concrete around it. dunno if the house part is 2 story or not. it better be awful danged fancy for that amount of money! whew!
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4370 |
Look out world Shammers is going to put the "pretty machine" in the garage. No going outside to refuel or adjust the throttle when he gets done.
Kurzy
Orange Level Joined: 02 Nov 2009 Location: WSS, Montana Points: 808 |
Howdy All, We just built house , shop and pole shed. We wanted steel too but after buying a bundle which is complete framing for a house, they had the price so high and you had to put it up yet! Full payment up front and wait for delivery. Some waited over a year! So we got wood. They have told us takes two years for new construction to dry out. It better hurry! Once it gets cold doors start to get tight. We been told the wood is not dried like it used to be! So I think there is problems on both sides. Thanks Kurzy
tomNE
Orange Level Joined: 13 Sep 2009 Location: dorchester, ne Points: 1218 |
I would also lean toward the 'T' type building! we stay in a nice simple house in arizona that has plenty of room. A lot better then the townhouse we moved into, when we sold the farm acreage!
shameless dude
there are companies that are building steel framed homes that look like any other house around. some include steel studs, some don't . we are looking at a "T" style, living T'd off a machinery type shed that is taller than the house part. with the steel wall inside the divided buildings, it creates a fire wall. aside from the heated floor, sewer pipes, other plumbing, and electrical, the old lady....oooops....i mean the loving wife and myself plan on finishing the interior ourselves. we have built our own bath and kitchen cabinets ourselves in the house we currantly live in. we also want knotty pine for walls, and unsure what the ceiling will be yet. there is a reason for the larger machine/garage area that i won't address at this time. having never had a garage before, it'll be a welcome site to be able to walk from the vehicle to the house in a dry non windy area.
tomNE
my theory is to avoid wood, where ever possible!
tadams(OH)
Orange Level Access Joined: 17 Sep 2009 Location: Jeromesville, O Points: 9690 |
A steel building seem like that would be less likely to happen if you used steel studs than with a wooden pole building.
darrel in ND
Orange Level Joined: 22 Nov 2009 Location: Hebron, ND Points: 8590 |
I have always wanted a nice heated shop with living quarters in it. My only reservation (other than lack of money) is that if your shop burns down, so does your house, and if your house burns down, so does your shop. If I ever could afford one, I probably wouldn't let that qualm stop me from doing so though. Darrel
tomNE
this is alot closer to what i want!
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78102 |
tomNE
no stairs; something like a 3 bedroom 2 bath with oversized 3 car garage. front to the east so an overhang on that side.
Current place is two BR Upstairs at Grade level, two steps in from Garage or off front porch. Laundry, Pantry, TV room, Kitchen, Most of daily life supplies all on that level. Basement has two BR, large sitting area/TV room just as Upstairs, utility runs in a long corridor along face wall of basement and some storage. Knees no longer enjoy steps but make the effort for now.
i have a single story house with attached garage for most work.. Figured that out 40 years ago... Dont want a 2 story, but if i had one, i would make sure main bedroom / kitchen / living room / laundry were all on the first floor... Upstairs could be long term storage, 2-3 bedrooms for kids when the visit , extra TV room, etc..
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4431 |
For years I preached how much less expensive it was to build a two story house with reduced foundation and roof costs. Now, as I am older, I wouldn't even consider a two story and I am thinking of changing some of my entry steps to ramps. My grandson currently has a broken leg. It makes me realize what a problem steps can be.
tadams(OH)
Building a building like that when your young is great but as you get older the stairs can become a problem. Where and attached home and garage-shop is more convenient
what kind of layout were your thinking ? Big garage attached, or BIG BARN size ? Less house, more house ?
tomNE
steve; not a design i would want but this is a picture of the kind of building that i wanted to know about!
one example.......
DanWi
Orange Level Access Joined: 18 Sep 2009 Location: wttn Points: 1708 |
Since alot of people just had a little taste of cold weather, one thing I will say is on a friends office area they built connected to the shop so they didn't use up shop space. Someone wasn't thinking and they put some water pipes in the north wall anyway a few winters back one cold spell they had frozen pipes. I don't know if it was pex just guessing because nothing broke. Part of the problem also is the wainscoting on the outside looks nice but it is another seam for cold air to blow in. When you look at what some of those guys have done with shop offices/lunch rooms it is easy to say I could live in that.
Most all steel buildings do not generate much rust or corrosion, encapsulated they remain contaminant limited and not much chews on them to cause rust.
