wiring |
Post Reply | Page <1 10111213> |
Author | ||
Gatz in NE
Orange Level Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1034 |
^ true.
Dad used to reverse them in the winter time when feeding cattle to prevent mud packing up inside the rims…the yards could really get messy. It even had tirescrapers. Sometimes he wouldn’t turn them around 'till late spring. That WD steering wheel just about took your hand off when discing plowed ground…. got to where I steered with a very light grip.
Sponsored Links | ||
Gatz in NE
The wheels/tires should be at an angle. On a diagram of the Front
Support, I measured 5º per side tilt outward at the top of the
wheels/tires . IDK if that's exactly correct, but it's very close......could be 4.5º This is what your WD45 should look like. If not, there's something seriously wrong ! Steve is giving good advice. Start a new post for changing topics; avoids confusion and makes it easier for people to help.
BTW, Here's a PDF for the WD/WD45 (and some other smaller ACs) If you don't have a manual, it would benefit you to download it onto your computer Edited by Gatz in NE - 15 Sep 2022 at 7:35pm |
hunter321
Silver Level Joined: 11 Jan 2021 Location: 52320 Points: 475 |
> will put the rims on the opposite way I took them off and see if they slant properly
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78050 |
the axle stub shafts are not horizontal.. they are welded together at an angle so the rims will slope out.... Either the shaft is bent or the bearings in the wheel hubs are worn , if the tires appear to be no angle outward.
Gatz in NE
That will not make a difference.
hunter321
There might be a slant but the front is too wide to notice right now
Gatz in NE
hunter321
They are slanted
hunter321
nowhere around me can find the front pedistal bearing
once again the race said 11480w haytt nothing on the bearing im stuck and cant move forward any help is greatly appreactiaded
Dr. had the ALLIS numbers a couple pages back, and the Dealer you can buy from... Also can order On-Line if you dont have dealer close.
hunter321
It took me to another forum with no information on where to get or numbers
Orange Level Access Joined: 12 Sep 2009 Points: 19592 |
Page 10 on August 29th I gave you part numbers and phone number to your closest AGCO dealer.
Edited by DrAllis - 30 Sep 2022 at 5:18pm |
hunter321
I bought them and they work
I think the only things I have left are picking up my tires and double checking the electrical |
I hope you hand packed that bearing full of good heavy grease ???
hunter321
I did
hunter321
One one of my other wd45s a rod that was connected to the foot clutch broke inside the rear axle I think any idea what that rod is
hunter321
Can I buy only carburetor jets for the wd45
Which brand carb???????? Marvel Schebler or Zenith ?? pretty sure you can buy adjustable main jets but any internal ones (other than needle and seat) maybe not.
Some of the kits are just gaskets, but some "appear" to have more parts like shafts and jets for a complete rebuild......... Depends on what you got and what your needing..
https://www.steinertractor.com/ACS3565-Premium-Carburetor-Repair-Kit?mkwid=|pcrid||pkw||pmt||slid||pdv|c|product|ACS3565|pgrid||cpgnid|17561055353|ptaid||adtext||&gclid=EAIaIQobChMIuLPDvvLn-gIVkh6tBh1p5w83EAQYASABEgKtsvD_BwE |
hunter321
i need all new jets cant remember the modle right know
hunter321
I'm having trouble getting the old jets out I've tried to use extractors
boil the carburetor in soapy water.
Gatz in NE
Don’t ruin the slot in the jet !
If boiling in soapy water doesn’t quite free them up,
Get a 1/4” hand impact driver to get them out. Amazon has one. Very important to know how to use the impact driver, though. Lightly tapping works best. Edited by Gatz in NE - 21 Oct 2022 at 1:48pm |
hunter321
The slot broke so I tried the exctracter
hunter321
Does the brass tube in the bottom part of the carburetor come out.
I have a tsx 561 |
the body is steel and all the jets are brass... and they all screw in... here is what they look like...
hunter321
ok i got every jet out but the middle tube one nothing is working on that one. can i just drill it out?
hunter321
Whats the best way to remove the tube jet thing
