Air Leaking Into Fuel System |
DKB552
Bronze Level Joined: 28 May 2019 Location: Georgia Points: 15 |
Posted: 12 Dec 2020 at 6:18pm |
I have a John Deere loader with the 3179 diesel engine. With the engine running rough I noticed there are air bubbles entering the fuel filter. I checked all lines and found nothing wrong. Could it possibly be a bad fuel pump or bad injector pump allowing air to seep into the system??
NomoreJohnDeere
Silver Level Joined: 24 Jul 2017 Location: Missouri Ozarks Points: 308 |
how do you know air bubbles are entering the fuel filter?
HD3
Dnoym N. S. Can.
Orange Level Access Joined: 03 Oct 2009 Points: 544 |
some John Deere used glass filter could possibly be a bad fuel pump sucking ail HTH B:-) DnoymEdited by Dnoym N. S. Can. - 13 Dec 2020 at 6:40am |
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7946 |
Clear fuel filters alow you to see air bubbles, had an AC 200 do this and it was a rubber grommet in bad shape letting air in on a metal fuel line - new rubber grommet no more problems
NomoreJohnDeere
If it has a transfer pump with a rubber bladder that is breached it can feed air
HD3
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29500 |
Even if Gear pump and seals are failing can suck air.
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4768 |
The filter base for those Roosa Master square filters have a bleeder screw that is supposed to have a rubber seal, and it gets old and torn off, allowing air in.
DKB552
From the fuel tank there's a clear automotive type filter that runs to the inlet side of the mechanical fuel pump. Then from the fuel pump a line connects to the big square glass filter mounted on the engine. The air bubbles (a lot) are seen in both filters. Both filters are not that old and are clear. The flow of fuel is restricted due to air entering the system. So could it possibly be the mechanical fuel that's bad?? I'm hoping it's not the fuel injection pump itself because that thing is around $1,200 dollars.
NomoreJohnDeere
I would think it would be between your first filter and the tank......
What kind of line/fittings? Low on fuel in the tank and sucking air? Find a suitable temporary fuel tank and run a line from it to your mechanical pump, gravity feed and see if the same thing happens |
HD3
DKB552
I has a mechanical fuel pump and a fuel injection pump. Where is a "fuel transport" pump located? As far as I can tell it doesn't have one
DKB552
Good idea. I'll try using a separate fuel tank and see what happens.
NomoreJohnDeere
mechanical fuel pump = transfer pump = fuel transport pump = lift pump
it feeds (sucks) fuel usually from a tank below the injection pump and keeps injector pump fed at low pressure I suppose there might be an injector pump with a lift pump built in that I am not knowledgeable enough to know about some may use a 12 volt pump in place of an engine driven one |
HD3
Jim.ME
Orange Level Joined: 19 Nov 2016 Location: Maine Points: 934 |
If there are air bubbles entering that clear, automotive filter which is between the mechanical transfer pump and tank the problem is pretty much certainly between the inlet of that filter and the tank. That filter is something someone cut the line and added in for some reason, likely trying to save money by not having to replace the designed fuel filter, because the tank has/had a problem with crap in it. It does not need to be there, by design. You may need to drain the tank and remove the filter, line, and fitting/valve in the tank to clean them. Check the fittings when reassembling to be sure they are not damaged on the seats. Check the shut off valve at the tank to be sure it is tight around the valve stem. Restriction in the valve body could cause air to be drawn in around the valve stem. What model is this loader tractor?
injpumpEd
Your injection pump should not be causing air in the filters that are ahead of it. And not sure where you're going, but a Roosa/Stanadyne DB is not typically 1200$ unless you have one seize. Did you check the bleed screw on the filter base itself? It is supposed to have a thin rubber sealing washer that is usually torn. Air ingress can damage the injection pump though, it causes the cam pin to break. The poor running may not be because of the air, it may be other pump issues, which cause the return to plug. That makes them run poor by not allowing the timing advance to work properly.
Edited by injpumpEd - 15 Dec 2020 at 8:03am |
DKB552
Yes, someone added that clear filter because they were too lazy to clean the tank out. (which I did clean last year and replaced the filter). The filter did allow me to see the air bubbles BEFORE the fuel enters the mechanical fuel pump so I'm assuming the problem may have something to do with the line going into the tank itself. I will try all these suggestions this weekend and I purchased a new fuel pump anyway because it looks as old as the machine. I will update when I discover the problem. This is a super rare 1980 Prime Mover LD50 articulating loader. They were only made a few years before the company went out of business. Very few of these can be found in running condition. I plan on posting pictures of it and the work I've done to it as time permits. Luckily I have a huge catalog that contains the owners manual, shop manuals and detailed parts diagrams with part numbers for every part installed on the machine. Finding parts is no problem.
DKB552
Thanks for the info. I plan to tackle the problem this weekend if the weather is good. It has the older model Roosa Stanadyne pump and the only ones I looked at so far were on E-bay for around $1,200 dollars. I'm sure I can get one rebuilt for half that price though. Right now I'm thinking the injection pump isn't the problem.
Jim.ME
Does that pull fuel out the top of the fuel tank or the bottom of the tank? The bottom pull would be flooded. The top pull likely uses a suction pipe inside the tank that is run down close to the bottom of the tank. If that pipe has developed a crack inside the tank it could be a source of air bubbles if the crack is above the fuel level. Depending how it is built that pipe might come out of the tank with the fitting the line to the transfer pump hooks to. As has been suggested, use a temporary tank and fuel line hooked to the inlet of the added filter to see if the bubbles go away. If they do, you know the source of the air entering is somewhere from the inlet of that filter back to the tank. (Which it would seem to me it is, since you say the bubbles show in the added on filter which is ahead of the transfer pump and OEM filter.)
DKB552
Yes, that makes sense. I plan on doing that first before changing the fuel pump. Using a separate fuel tank is a great idea.
DKB552
PROBLEM SOLVED. As someone suggested, the fuel pick up tube in the tank had developed a leak at the top of the tube. It now runs great!! Thanks for all the replies!!!
