Dr. Allis D17 XT Plowing
Message Reverse Sort Order
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Dr. Allis D17 XT Plowing
    Posted: 04 Dec 2020 at 5:35pm
Thank you very much for that info, I thought maybe the intake/exhaust would have given trouble Embarrassed . Well, who ever owns it next "probably" won't be going to the dealer for '17 diesel parts from the bell house forward Wink!!
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2020 at 7:22pm
The throttle was one of the easier things I did. Still used the original throttle linkage from the steering wheel to under the fuel tank, but replaced the link rod that went from there to the gas engine with a new 1/4" rod about 4 ft long and made several kinks and bends and one guide bracket close to the injection pump. All things considered, it was easy and turned out well, as the stroke of the hand lever is 100% the same as the gas engine was.  The foot clutch area seemed to take the most time and then the steering. I had the engine in and out a dozen times before I was happy with the clutch. The gas chassis clutch shaft is too long for the diesel engine, so I figured out a way around that problem. I cut off the clutch shaft nose (for the pilot bearing) and found a new pilot bearing that would slide on the new larger clutch shaft diameter and then machined the flywheel hole deeper and larger diameter to accept the new pilot brg. Then, the clutch disc had to come from a maroon model 7000, as it has an offset clutch hub in it, offset towards the engine, which I needed. The rest of the time was spent machining the flywheel to fit .100" farther forward on the crankshaft, moving the starter ring gear .100" back on the flywheel to locate it correctly, and machine the flywheel wear surface .100" to get the clutch disc to fit on the clutch shaft splines and not bind. The shorter throwout bearing sleeve had to come from a D-17 diesel to get it to locate properly to the 180/190 pressure plate.  Some grinding had to be done to the inside of the bell housing to get it all in there, but after you grind enough away in the right spots, it fits.  I am fortunate to have a lathe at work to be able to do many of these things, instead of hiring it done. It was important for me to get the engine to sit as far rearward as possible, because I had to design a way to be able to steer the tractor with a narrow front end and needed the engine to be as far out of the way as possible. As it turned out, the steering turned out just fine and it had its engineering problems too, but all worked out. Hydrostatic power steering that didn't change the looks or length of the tractor was the goal and I was lucky it came true after lots of thinking. I always felt if the narrow front didn't work, I'd just switch to a wide front and mount a steer cylinder crossways on it. Didn't need to and as it is now, it could be switched to a wide front with an OEM steering arm. One can always have a "plan" before he starts a project like this. Funny how the "plan" has to be changed up a bit as you go along !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2020 at 5:55pm
Thanks for the pictures of the process that went into the '17 ! May I ask what the most time consuming/$$ fabrication was ? I realize it's trivial to most of you guys, but I've been curios how the 433 FP linkage was mated to the '17  throttle linkage Embarrassed . Thanks again for all that you bring here Thumbs Up
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2020 at 8:13am
Yes, Dr. you are correct.  The shipping stands were solid on the bottom and I believe a little taller than your step.  I just thought maybe someone modified it by making it shorter and drilled some holes for drainage.  But, you're probably right; it isn't what I thought it might be.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2020 at 4:14pm
That step was on the tractor when I bought it, so I have no idea.  I doubt that it is what you think it is, as the floor part of it is full of holes like a grinder mixer screen. Those shipping stands were solid, right ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2020 at 2:38pm
The triangular "helper" step mounted on the left side looks familiar.  It reminds me of the "stands" that were mounted on the back of AC cornheads when they were shipped upright (standing on their backs).  We used to pick them up from LaPorte and used many of those "stands" as steps for several different models of AC tractors.  It was just something we did at the dealership; not an AC approved modification.  Just curious if that's where your step came from.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2020 at 10:41pm
Dr. Allis,
You missed your calling! Engineer at Allis Chalmers and what a tractor that D17 would of been! Way to go. God gifted you with an amazing brain and desire to do some neat things. You are a real asset to the Allis Chalmers community.
Pastor Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2020 at 10:43am
https://photos.app.goo.gl/asormkrGTppYUWex5
Pics from the build, including the 3-point hitch removal to be able to use the snap-coupler plow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2020 at 12:03am
Wow that's cool. Have any other pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 9:21pm
I have a 45D carcass around here I thought would make a good candidate for a 433T....just too many other things take precedent.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 5:40pm
And now days just about all tractors in this HP range and even smaller have a turbo!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 5:33pm
The D-2200 engine wasn't enough HP, as it was naturally aspirated and only 200 cubes. I think they were 50 flywheel HP, while a One-Seventy needed 65 to 67 flywheel HP @ 1800 RPM to deliver 54 at the PTO.  So, that means more cubes (230 to 250) or a TURBO !! Even if the D-2200 with a turbo (D-2400) cost more than a Perkins, it would have been worth it in my opinion.  Imagine, the only diesel turbo farm tractor in the 55 HP class  !!!!!
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 4:24pm
I put a 433 in a 175 about four years ago took the perkins out tractor runs quieter with a strait pipe and more power , I have late model black engine starts great ,
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 4:09pm
The 200 cid 4 cylinder was used in the HD4 crawler as the 2200 series, sad the tractor division was able to outsource engines from perkins for less than their own sister division of the same company.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 3:14pm
Well said about the AC 433I. Back in the late 1980s thru the 1990s, I’d usually get two full days (12-14hrs/day) running a hydro F3 Gleaner(70gal fuel tank) & A330 cornhead. It’s 433I was very economical, yet powerful.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 1:21pm
The history of the 4-cylinder version of the 301 began in 1965 from all I can find, within a year of the intro of the 301.  The 301 turbo was in 1965. It just looks to me like the original One-Seventy should have had this engine in it at 2,000 RPM. A little smaller turbo would have been fine for 54 HP. But instead a Perkins ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 12:57pm
This has bee fun to watch come together. This is what the D17 Series 5 should have been, instead of the Perkins, which are great engines no doubt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 12:16pm
I do.  The goal on this project was to try and make it appear as if it maybe could have been an OEM turbo-diesel installation. There were several hurdles, but in the end, we now have a powerful, economical and modern D-17. Hydrostatic power steering, live hydraulics with "float" position on the remote valves, a rugged Cat #2  3-point hitch that can easily be removed to still use the snap-coupler system, and the old high-pressure hydraulic system still intact. All original S3 D-17 features were retained with the addition of the newer more modern features. It was a lot of work, but all great fun usually is.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 11:22am
Looks great and works great Dr! Do you enjoy engineering/fabricating/designing?
www.awtractor.com
A&W TRACTOR 920-598-1287
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 8:48am
Loved the video! See that the good doc is a little camera shy himself though. Have to see what this Allis genius looks like some time! LOL! Keep up the good work, Dr. Darrel
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 3:12am
Looking good Doc, you done a great job even on the littlest details it looks even better up close.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2020 at 10:19pm
Yes, it is 14 to 1 compression ratio. I have the manifold heater on it. 30 to 60 seconds and it starts pretty well. Has a block heater too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2020 at 8:48pm
Those 433T engines are good ones. Our 81’ 6060 still runs great, plenty of power, no smoke until you roll the coal with a load, clears right up after its up to speed. Very fuel efficient. Nice set up DOC, cool project. Would have truly been a great setup for AC.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2020 at 8:37pm
That soil really rolls nice off the 14's... looks like it cuts and rolls same in 2-low as 2-high, which means you've got all the geometry dead-on-perfect, and ample force on-tap at the drawbar.  Great video, excellent sound!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2020 at 8:35pm
My 78 has 3300+ hrs . The meter was AWAL when I got it .I took it apart and oiled things and it's been working for last 20yrs. Doesn't use any oil and will lay a cloud when throttled up after snapping in separator clutch. Great little engine! I assume yours has the low compression pistons too causing poor cold starts?
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2020 at 8:21pm
Doc, shes looking good. That must be some heavy dirt.    Before I bought a decent disk and field cultivator I would plow corn ground in 2nd high side with a 3x16 slat bottom plow. I'd throw the dirt clear outta the furrow. I thought it was cool for a few rounds. Then I realized I'd have to level the dang field back up. Looks like fun, glad you got her all figured out. I really wish AC had put a diff lock starting with the series 4 D17 and later tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2020 at 7:33pm
Well, it was 30 degrees that morning, so the air was good for no smoke. The injectors have never been serviced on that 1978 model year engine. It must have had good care in all it's years of use. I'm guessing it has 3,000 hrs or less on the engine.  It will smoke when you crack the throttle when under the turbo for sure. All the good ones do that !!! The weights are what you do when you have a lot of that type laying around !!  The rear wheel weights actually go on and off much easier than any OEM donut or pie weight does. All you have to do is get the wheel positioned just right and they slide right into place.
Edited by DrAllis - 24 Nov 2020 at 7:35pm
SLee(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLee(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2020 at 7:30pm
I love the weights Doc.
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2020 at 7:19pm
Where's the smoke? My F2 hazes all the time. Similar to an N6 but not that heavy.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2020 at 3:17pm
The crankshaft thrust bearing in this 4-cylinder version of the 301 is the same exact thrust bearing as a 180-185-190-190XT-200-7000. We never had any issues with them. This tractors foot clutch is a flywheel/clutch disc/pressure plate from one of those bigger tractors shoved into the smaller D-17 bell housing. The 6000 series had foot clutch pressure PLUS PTO clutch pressure, which at times, was just too much for the thrust bearing.
Thanks...pretty much what I was thinking...but just wanted to ask you.  We have a 185 and two D17's and a 433 engine in our F3 Gleaner but never had a 6000 Series tractor.
That engine transplant looks like it came out of the factory that way.  Looks great.
