WC running rough while Idling |
farmboy59
Bronze Level Joined: 15 Mar 2016 Location: Gobles Michigan Points: 29 |
Posted: 21 Nov 2020 at 6:40pm |
Got an Unstyled WC that runs smoothly under a load. However if it's just sitting in neutral running the throttle surges. Carb and timing adjustments didn't change anything. Gonna adjust the valves and see if any are sticking tomorrow. Any other suggestions?
36 WC, 50 WD, 51 CA, 55 D-14, 59 D-17, 62 D-19, 73 610
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11558 |
Idling and surging could be a small vacuum leak somewhere. Spray a little carb cleaner around the intake manifold, Carb base, and where the intake meets the cylinder head. If you hit a spot where all of a sudden the engine smooths out and the surge is gone, you've probably found your vacuum leak. Also could be a little dirt in the idle circuit or a low float setting.... HTH Steve@B&B
B26240
Orange Level Joined: 21 Nov 2009 Location: mn Points: 3860 |
I'm going to say it's a carb issue, adjusting the valves will do nothing for a surging engine.
farmboy59
I should add that the carb is off of a perfectly running D-17. Before the carb swap I sealed the manifold gaskets with high temp permatex just to rule it out. I'll be putting the original carb back on once I go through it again and see why it wouldn't stay running with it on there. I figured it was a fuel issue as my D-17 will surge while working if the load screw isn't out enough. May end up having the manifold planed and install new gaskets.
Edited by farmboy59 - 22 Nov 2020 at 9:03pm |
DaveKamp
Orange Level Access Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5641 |
Check the distributor shaft for bushing slop, and check the advance mechanism for proper operation, either of those may give you similar issues.
