185 / 500 loader lift capacity |
185turbo
Bronze Level Joined: 15 Aug 2018 Location: Kansas Points: 92 |
Posted: 10 Sep 2020 at 8:23pm |
What is the loader lift capacity for a 185 with a 500 loader on it? I got to unload a truck that may have 2000-3000 lb pallets. Im thinking 2000 lbs is ok but not sure about 3000 lbs
185 turbocharged w/ 500 loader , WD
allisbred
Orange Level Access Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
I’m not sure but think 2000 is over the lift capacity.
Lonn
Orange Level Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29781 |
Lifted an N6 engine out of the combine with a 185. I should say the guy I bought the engine from lifted it with his 185. IMO that was too much for a tractor like that. I don't remember what he had for a loader but that front end looked like it was going to fold up. He backed straight back out of the shed then I backed the pickup under the engine. I was waiting for a spindle to snap. An N6 engine must be around 1,700 lbs.
Wink I am a Russian Bot |
Clay
Orange Level Joined: 11 Sep 2009 Location: Udall, Kansas Points: 8928 |
According to my model 500 series manual;
Lifting Capacity at Full Height D-17, D-17IV, D-19 2300 Carrying capacity @ 3 Ft. Height D-17, D-17IV 3400 D-19 3500 Breakaway Force D-17, D-17IV, D-19 4000 |
Gary Burnett
Orange Level Access Joined: 11 Sep 2009 Location: Virginia Points: 2855 |
[QUOTE=Clay]According to my model 500 series manual;
Orange Level Access Joined: 12 Sep 2009 Points: 19651 |
The load rating may be from the bucket pin area, not actually in the bucket itself.
bradley6874
Clamp on forks move the pallet wt completly out in front of the bucket greatly reducing loadrating
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29835 |
Have a set of forks for my 500 on a 180, due to Hydraulic pump age and wear, small dia of cylinder barrels and Reliefs settings in the controls mine will ONLY raise 2000 pounds. As far as front tires compressing is about all I will EVER put to it.
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7972 |
There not rated for much matbe 2000, i picked up a cube of brick with my 6060 and what ever loader fits on it and bent the tip cylinders, they dont leak but have definet bends !
Clay
Meanolallis
Bronze Level Joined: 04 Sep 2013 Points: 130 |
1981 brochure for 185 says: Lifting capacity to full height: 3400 lbs. Carrying cap. @ 3 ft. 3400 lbs. Max. Breakaway force: 4000 lbs. Max.
I think the full height value might be a typo since the other models (for 5040/5050/6060/6080) that carry ~3400 at 3 ft. are only rated to 1800-2000 at max height. |
Maybe, or they figure a 4000 lb tractor SHOULDN'T be carrying 3400 lbs overhead for fear of upsetting it ?? Where the 9000 lb 180/185 might be harder to tip over. ??
