Combine reel goes up- not down? |
dertz19
Bronze Level Joined: 22 Sep 2009 Location: Minnesota Points: 84 |
Posted: 06 Sep 2020 at 10:33pm |
I've got a '68 Gleaner G. Suddenly, the reel refuses to go down. I have to bleed the lines on the head to do so. It goes up just fine. All the other hydraulics work just fine and responsively, including the variable speed for the reel. The reel used to go up/down just fine. Then, after sitting outside for a few months, this problem arose. I replaced a steel hydraulic line on the header that was heavily dented, thinking that might be the problem- but no change. There's some very slow leaking out of the hydraulic control unit by the pump, but that's always been there since I've had the combine (7-8 years) and before this problem started. Suggestions?
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21486 |
OK, dumb question to ask ,but... ANY chance the safety lock is on ?? On my A there was a 'bar/lever/chunk of metal/??' that kept the reel up... Jay
im4racin
Orange Level Joined: 12 Jun 2017 Location: Garrison ND Points: 836 |
Sounds like bound up linkages not fully moving the valve spool or out of adjustment
Edited by im4racin - 07 Sep 2020 at 6:38am |
FREEDGUY
Possibly the quick-connectors ??
MACK
There is a plastic poppet in reel lift valve that can break causing this problem. There is a plug on valve above spool valve. Support reel and remove plug. The metal shaft will some times push through the plastic.
Also check couppler at header, point will wear off. MACk
dertz19
Thanks for the suggestions- I'll give them a try!
FREEDGUY
Any progress on the reel going down ??
dertz19
Unfortunately, I developed a problem- presumably in the carb- and I can't get the combine started. Hopefully that gets rectified soon...
shameless dude
had that happen on my "G" combine once, like Mack said...it was the connectors, replaced them and all was well.
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50548 |
Another problem that can develop is a an old hose can have a flap of rubber come loose, and act like a check valve. Allows flow, in 1 direction, cuts off flow the other way...
FREEDGUY
Sorry to hear about the "NO-GO" issue , hopefully that's a simple fix .
dertz19
UPDATE
Finally got the G running (looong side note- it was running great, then would suddenly quit. Would restart quickly etc. Then finally quit and would only fire once/twice on restart before dying. Thought for sure it was a fuel supply/ carb problem. Turned out to be a bad resistor). Anyways, I checked the plastic poppet valve on the control unit by the hydraulic unit as per MACK- that was fine (who would have thought a non-cosmetic part on a '68 Gleaner was made of plastic?). Next, on to the appropriate 1/4" hydraulic male poppet connection on the header. Wasn't optimistic about finding one that size at one of the local fleet stores on a Sunday, but did after a few stops. Noticed the collar on the new one was located differently than the old, so I was skeptical it would fit, but then realized I have updated the hoses/ connectors coming from the combine in the past. SOOO, turns out THAT was the issue. After installation- EUREKA! the reel goes up and down. Curious thing is that I'm pretty sure I updated the hoses/ connectors coming from the combine AFTER this problem with the reel started several years ago. I have decided not to worry about it now. haha. Thanks for all the advice.
