Wanted, D17 diesel block |
randy
Orange Level Joined: 12 Sep 2009 Location: Illinois Points: 1177 |
Posted: 03 Sep 2020 at 6:57am |
Looking for a block for a D17 diesel. PM or text 217 898 6139
Thanks, Randy
Orange Level Access Joined: 12 Sep 2009 Points: 19546 |
What age tractor ?? What style water pump ?? You want a gas block if possible.
randy
1958, water pump, not sure about that. there is a hole in the center of the block on the left hand side. Cant post a pic yet. Open to any ideas
Acdiesel
Orange Level Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2506 |
I Used a Gas block on my D19 Diesel and all the liner protrusions were right on.
Is your water pump mounted on your block or cylinder Head? there is one on Ebay for $400. Link: ALLIS CHALMERS D-17 6 Cyl 262 ci 4.3L Bare Engine Cylinder Block 4516682 Diesel |
D19 diesel,D17 diesel SER.3 D14 NF,D14 WF, D15 SER.II wf
D15 SER.2 DIESEL,D15 ser.II nf D12 SER.I, D10 Ser.II 2-720'S Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
Charlie175
Orange Level Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6351 |
So a 262 gas block can be used as a diesel block? Didn't know that.
Charlie
The D-19 came out in late 1961. At that time the water pump went from the cylinder head down to the front of the block. I would imagine the D-17 engine got the same change at the same time. All D-19's were 262- wet sleeve engines with the water pump mounted on the block. That means gas-diesel and LPgas were all the exact same engine block. Gas/LP blocks are perfect for a diesel restoration, as the lower compression ratio hasn't pounded the sleeves below flush. Unfortunately, AC never had a 262 gas version in the old block/water pump design that they used in farm equipment. There sure could be such a thing out there on a gen set, water pump, etc.
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3735 |
you can have the block decked a few thou and recut the counterbores. if you get another block i would sure have it checked before just throwing parts in. We were going to have our block decked but it had cracks so we went with a gas one. still ended up taking a couple thou off the top to get all liners +.004.
Edited by CAL(KS) - 03 Sep 2020 at 12:50pm |
Not sure how much you can deck the block without having to cut the same amount off of the pistons. Pretty sure things get really close when the block gets decked very much.
Brian Jasper co. Ia
You can use the later style block with the early head. I have a later gas block in my early D17D with the pump on the head. I just made a block off plate for the block pump and from there it's the same besides the turbo drain hole.
randy
I could use a d19 gas block, close to east central Illinois.
rtwfarm
Orange Level Joined: 26 Feb 2012 Location: nebraska Points: 1250 |
Got a few blocks in Nebraska. Ryan at 402-469-1738
randy
Found one! Thanks for all the help.
Randy
