Allis chalmers 715c hydraulic pump |
ac89
Silver Level Joined: 18 Mar 2015 Location: maine Points: 325 |
Posted: 26 Aug 2020 at 2:44pm |
Can you still get a hydraulic pump for the allis chalmers 715c backhoe with the allis chalmers 433t motor? Or will my best bet be my hydraulic shop for a rebuild. I think its a Cessna pump.
Edited by ac89 - 26 Aug 2020 at 2:44pm |
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29511 |
Hydraulic shop will be your best bet, if need a Eaton Cessna they tend to still be available just have to match specs and drive spline.
ac89
That's what Im thinking. It'll be a good project for this winter.
Edited by ac89 - 26 Aug 2020 at 4:02pm |
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41201 |
I had a Cessna pump on a New Holland skid steer that went bad was over $1,000 from dealer - hyd shop had a new pump for $300 but input shaft was different as NH had a propitiatory design - thing is old shaft was good and fit right into new pump - did the exchange of shaft in the price .
Check with a shop or with MINNPAR to see if they have it in stock but be ready for $$$. Can try Surplus Center to see what they have that might exchange also as they can match many units for pumps and cylinders |
ac89
Ok I will have to look into that thanks
ac89
I found a pump online that is identical on the outside of mine. But it doesn't tell me the specs.
Almost looks like the trans pump for my 7G
Can go to Eaton Cessna and look up by pump number for specs.
Edited by DMiller - 31 Aug 2020 at 3:10pm |
ac89
I'll try that thanks
markjlemmon
Bronze Level Joined: 11 Sep 2020 Location: Fresno, CA Points: 2 |
Hi, This is Mark.
A 715c hydraulic pump can handle fluids that are too viscous for a centrifugal pump. The pumping action is very controllable and mathematical. if you double the speed, you double the output. |
Coke-in-MN
