Large "Barn" Project ?? |
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29696 |
Posted: 10 Aug 2020 at 12:04pm |
Money not a problem, Red Iron.
GeneD14
Silver Level Joined: 17 Sep 2009 Location: TN Points: 235 |
In many areas a pole barn style building is taxed at a lower rate than conventional stud wall framing. But it sounds like money is not an issue.
FREEDGUY
Yes Jay, this cat has virtually "endless pockets". His family runs an asphalt company in Chicago There will be NO exposed framing, conduit ,plumbing or heating elements exposed . This will be finished "inside" like a 5 star hotel .
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11421 |
A 3600 sq ft “studio apartment”.
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21584 |
wow someone has very 'deep pockets' ! 7200 sqft with heat and A/C that's over 115K cuft of air to deal with....ka-ching, ka-ching.. Obviously a professionally designed/installed 'PEX in well insulated concrete floor' is the starting point... Up here sprayfoam is $4 a foot and the only 'sane' way to do a building that big to seal and insulate. I'd run all electrical outside of the walls,in conduit. Saves a ton of money in energy costs. I'm thinking white tin ceiling and walls, with windows all around ,say 14-16' up,to let in daylight...
Expense wise look into red iron building projects. Cheaper and more durable than Pole or conventional structure in the long run. Can be sized to meet needs and clear span. Steel Sided, no worries of Treatment chemicals destroying tins, or affecting occupants. No conventional Trusses so height becomes Nominal at Joist Beam height. Poured floor/rim Footer foundation, Cast in place bolting positions, that is why used in commercial style construction. Faster build, straighter lines, stronger materials. My Next structure will do this as can build Huge for the same cost as wood where less expensive insured.
Are many others
Edited by DMiller - 08 Aug 2020 at 8:00pm |
jiminnd
Orange Level Joined: 16 Sep 2009 Location: Rutland ND Points: 2210 |
Lots of large pole buildings built here for shops, completely insulated and finished, seem to work good. Can also add an office on the side if you need and it will be as nice as many houses. My brother did this, 80 by 100 shop with a 32 ft square office on the side.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78075 |
pole barns are anchored TIGHT to the ground ( poles buried in concrete.. You can tie them together with horizontals and finish the outside with tin... tin does not fit on vertical studs too good... depending on what he needs on the inside, he is going to insulate and put additional framing.......
i would think 16 ft tall studs would be hard to anchor down against high winds.
Edited by steve(ill) - 08 Aug 2020 at 7:40pm |
FREEDGUY
More so than framing in between the posts later ???
16 ft 2 x 8 studs is going to get expensive !
FREEDGUY
I have an acquaintance that is wanting to build a 60x120 "pole barn" that will be used for "mostly" boat/rv storage, but is also going to be 100% climate controlled with 50% utilized as a "studio apartment". The side walls are 16',not sure on the exterior siding yet. He's leaning towards a true "pole barn" construction, but I suggested 2x8 stud walls on 2' centers on top of a monolithic poured floor . Am I wrong in my thinking?? Thanks
