6080 PTO RPM?
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Topic: 6080 PTO RPM?
    Posted: 07 Aug 2020 at 5:25pm
My 6080 has a replacement tach with no PTO symbol. The manual says use the tach but doesn't say what PRM. I have been running a 9 foot flail mower at 1700 RPM and it does fine but just wondering where I should run it.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2020 at 6:57pm
Good question so I thought I would get the 6080 out.  Here is the PTO at 546 RPM.
Here is the actual engine RPM.
Here is what the tach says.  Looks like the tach is about 60 to 75 RPM's off, but pretty close.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2020 at 7:26pm
Thanks for taking the time to do that. Looks like I won't have to run my tractor that hard to cut what I want with it which is good news.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 11:02am
How the heck does that digital tach work???? Could be nice to have one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 4:37pm
This is the 3rd one I've had.  First one I dropped, and the second one grew legs out of my toolbox.  They are pretty cheap for what it does, 8 to 10$.  It uses a piece of reflective tape on a shaft and when you push test, the beam bounces off that tape.  Can't use it where the sun shines on that tape, just have to shade it.  They come with a foot or so of tape and I only use 1/4" at a time or you can buy those stick on trailer reflectors.  Works good for setting governor speed on the single cylinder lawn mowers also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 5:15pm
Thanks Lon! Would be handy to have on hand and cheap! My shaft tach dont fit in some places plus the rubber tip is shot.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 9:08pm
The owners manual could tell you the engine RPM
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2020 at 1:01pm
Most Allis run at 2200 for 540- as long as its doing a good job - run it there
