Aux electric fan on condenser |
Post Reply | Page 12> |
Author | ||||
TimZ(TX)
Silver Level Access Joined: 12 Sep 2009 Location: Katy, TX Points: 255 |
Posted: 10 Jul 2020 at 5:57pm |
Anyone put an electric fan behind the A/C condenser on a 8000 series tractor? Being over 100 degrees here in central Texas is hard to cool. Or should a working system never need that.
Tim
2-B's,CA,D15,D17,160,2-185's 8010
Sponsored Links | ||||
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21507 |
I'd add one, if only to try, that way YOU will KNOW if it works or not...... If you can put ,say 1' tall sides to create a bit of a chimmney to force he air away, that should help too.
MACK
Will help but won't cure the engineer's mistake. MACK
scott in tenn
Bronze Level Joined: 27 Oct 2009 Location: selmer tennesse Points: 61 |
I put 2 10 inch fans side by side on my 8050 this spring. Made a world of difference on mine rolling hay.
Orange Level Access Joined: 12 Sep 2009 Points: 19560 |
Before doing all of that, are you sure the radiator has all the sealing foam around the top, front bottom and sides?? Air must come thru the grille for the system to work properly. Also the radiator and hydraulic/trans cooler must be CLEAN for air to flow easily and the plastic fan shroud has to all be there and not broken up. Until this post, I've never heard of having to add extra cooling fans.
Edited by DrAllis - 12 Jul 2020 at 4:28pm |
MACK
never saw a 8000 series that would run under 250 psi on hi side. Most 300 + Eat compressors and clutches . MACK
scott in tenn
Seals around radiator are good and radiator and cooler clean along with condensor. 98 degree day stop and go baling temp keeps climbing. Aux fans took care of problem for me. Head pressure is running lower with fans also.
ryan(IN)
Orange Level Joined: 11 Sep 2009 Location: Bluffton,IN Points: 745 |
AP air has an add on condenser kit for the 8000 series. Says along with the original it lowers high side pressure and increases cooling.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62 |
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29595 |
If can maintain significant airflow across a condenser the pressures should decrease. We used box fans sitting in the shops long ago to lower head pressures while testing systems. Another consideration is making sure the influx of moist hot air is limited to the cabs so the evaporator is not trying to cool the entire world around the tractor, that any cab filtration is clear and that insulation is well in place.
Interesting. I must live farther north of the equator and haven't ever seen the need for this yet. I also wonder if the condenser was hanging straight down instead of angled if that wouldn't help some ??
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8018 |
I'm in central Illinois and most tractor work is in spring and fall so temps aren't that high but for 2 August summers I bat winged 30A for an uncle and stayed plenty cool in my 8070. Factory system converted to 134. Surprised to here of these problems. That fan moves a bunch of air.
TimZ(TX)
I put new air filters in, washed out all condenser and radiator. Pressures are good just struggles when it's 104 out. Which it was all weekend. As soon as I spray water on the condenser it'll freeze you out. Just ordered a new door and window gasket set from Fehr. Scott I assume you put two fans that pull air since there's not much room in front of the condenser. Do you remember which fans you used?
scott in tenn
Yes. 2 10inch fans that are pulling air. I still have the box and can post part number this evening.
wekracer
Orange Level Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1587 |
I have an 8010 8050 and 8070. I have to admit that I don't ever remember actual temp hitting 104 but it does get in the upper 90's.
I pull a 13' disc mower with the 8050 and it will keep me comfortable at 95*. It got an engine rebuild along with new ac compressor, dryer and expansion valve about 10 years ago. I wanted to put a Sanden on it but dad was paying the bill and so we went with factory replacement. It also got the radiator recored and new foam kit from Fehr about 5 years ago. the 8010 pulls a 15' batwing and round baler. It got a Sanden compressor, hoses dryer and expansion valve about 3 years ago. I think it probably needs a new cab blower as it doesn't seem to have the volume the other two do, but it will keep me comfortable. Wednesday is supposed to be 97 here and I plan on clipping pastures. We will see how that works. The 8070 had a Sanden compressor when I got it. It doesn't do much in the summer but I have pulled tillage equipment with it at 90* and it cooled just fine. I like it to be around 250 lb head pressure on a 95* day. I'm no expert but one thing I cant stand is being hot in a cab. Good luck |
AC7060IL
Orange Level Joined: 19 Aug 2012 Location: central IL Points: 3208 |
Unlike the usual excess of midwest humidity, the Texas heat could also be coupled with lower relative humidities.
For example, today’s forecast for humidity levels(RH) & temps (T) per my central IL versus your Katy, Texas during peak afternoon hours; Time. IL-T. IL-RH. TX-RH, TX-T 2pm. 81. 53. 50. 95 3pm. 81. 53. 46. 96 4pm. 82. 50. 43. 98 5pm. 82. 51. 43. 98 6pm. 81. 52. 43. 98 7pm. 79. 56. 48. 95 8pm. 76. 63. 59. 90 Not only are your TX air temperatures higher, but your relative humidities (hour by hour) are 3-5 % lower than here in central IL. Lower moisture in the outside air that’s being pulled thru the condenser will not cool as well as wetter air. Higher outdoor air humidity helps cool the compressed AC charged gas into a liquid form at the condenser better than drier air. |
AC7060IL
Instead of an auxiliary fan, you may be better off to add a misting spray ahead of condenser??
Then dirt would stick to everything ahead of the fan.
wekracer
So your saying it’s the humidity. Not the heat? |
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3297 |
out here in utah we have 100 degree days alot alot of upper 90s, we are very dry basicly no humidity , and i have struggled to get any brand of tractor to cool very good when changing them from r-12 as compared to tractors that came with 134 so i am listening to what you guys have to say
jes thinkin out loud... Every Ford I'e every owned had 'freezer cold' A/C, even the diehard Chevy guy next door ! says Ford's is the best. I'm wondering 1) what makes their system so good and 2) could it be adapted for a tractor cab ? have to ask do the trucks you guys drive 'down there' have better A/C than your tractors ?? If so...then there's something 'wrong' with the tractor A/C design or parts or setup.
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3142 |
Just a thought here but tractor cabs seem more like a greenhouse with all that glass than a vehicle. And those systems are really just designed to lower air temperature 20 degrees relative to ambient temperatures?
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11398 |
Well, YES! The heat energy required to handle that vapor is many times over that of dry air. |
well it was 132*F in my Ford the other day......according to the IR gun I use.. After getting rid of some of the hot air via open windows, then turned on AC to max, it got quite chilly after a few minutes(10-15). You guys in the deep south must have hotter cars....... just saying if car ac works , tractor ac should.
TimZ(TX)
I think one of the biggest problems with cooling the 8000 series is the amount of glass. I see some guys put dark tint on there windows to help block the sun. Our car air conditioners work great. I especially like my air conditioned seats in my Ram truck. We generally have high humidity 65% and up. When it's bad we have the old 95/95. 95 degrees with 95 % humidity. It'll zap you quickly. Lately we are really dry so the humidity is better.
Tim
wekracer
It was a joke. Maybe a Missouri thing. Everyone always says it’s the humidity, not the heat that is so miserable. I have a fair understanding of thermodynamics ;-) |
Tbone95
I knew it was a joke....and made my comment anyway.....sorry for the way it came across. |
Tbone95
How fast were you driving? All that air moving over it takes a LOT of heat away, probably faster than most tractors at least. You have more insulating materials and dead space in your doors, firewall-dash, ceiling, floor than most tractors I suspect. You probably have a very controlled amount of outside air coming in, adding to the heat load, max does a recirculate, probably not on most tractors or wouldn't work that great anyway. Oh sure, the newest latest greatest tractors probably OK. Glass surface area ratio in a tractor and type of glass. Hydraulic/transmission hot oil circulating various places throughout/right next to the cab. Edited by Tbone95 - 14 Jul 2020 at 1:02pm |
Musketeer
Bronze Level Joined: 17 Aug 2014 Location: Kentucky Points: 9 |
I moved my condenser forward away from the radiator and added two electric fans several years ago when I converted to the sanden compressor Have not had an A/C issue since, other than normal maintenance / cleaning. I hope this info helps, good luck.
B112
D19 185 6080 fwa 8030 G |
sitting in my driveway..... hard to believe a tractor cab on the move gets hotter than my parked, black pickup max does recirculate, unknown what tractors do,heck none of my D-14s have cabs ! reg cab Ford ,all black....it gets HOT I'm just wondering why tractors don't get cold....
Red Bank
Orange Level Access Joined: 18 Apr 2018 Location: Germanton NC Points: 1049 |
just an idea not my tractor lol
