Allis Chalmers WD45 Diesel project
 Post Reply Post Reply Page  <1234 8>
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 10:33pm
How hot does a d19 diesel run at for temperature? Got the head off and looked in where the thermostat is a suppose to be And there wasn’t any in there, so trying to figure out how hot to go with.
              Thanks!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2020 at 7:42am
How hard is it to get the timing cover off?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2020 at 6:40pm
Got the timing cover off by Loosening the frame rail and it came right off. Got the head on and the manifolds. Now just waiting on parts.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2020 at 8:00am
Ah, 'Parts Needed' the story of my life!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2020 at 8:26am
Thermostat missing ?? probably because the engine runs hot under load due to a WD45 sized radiator...……...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2020 at 11:51am
Had it running before I tore it apart and driving up a road it would get to about 180 degrees on a 93 degree day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2020 at 11:59am
So, how hot do you think it would get pulling a plow on that same day?? Driving down the road isn't much of a load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2020 at 2:04pm
Not completely sure but 30 years ago is when my cousin use to use it and he said it never got to hot but that was 30 some years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2020 at 7:01pm
Got the valves all adjusted
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2020 at 11:13pm
Can you find a fan with more blades so you can move more air thru...?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2020 at 8:09am
It has a five blade fan on it right now
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 12:18pm
Got it all back together today and it ran nice and smooth.
Will send a picture of it , don’t have a updated picture yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2020 at 5:23pm
Here it is after two hours of running. The injection pump is leaking a little but not enough to worry about.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 9:02pm
Is it possible to add another hydraulic tank so it can have more oil on the factory hydraulics system?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 9:15pm
What are you attempting to do ?? I suppose a tank could be mounted outside the frame and the bottom of it plumbed to the torque tube drain plug. It would have to have a good breather on the top of it to let oil go in and out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 10:19pm
It won't make the hydraulics work any better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2020 at 8:44am
Isn’t it a high pressure lower volume? Thought if I could add more hydraulic oil to the system it could pick up things that take more oil.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2020 at 8:51am
yes that is true.  but as even Dr Allis has stated before,  the D19 Hyd system is pretty lackluster.
to add to the comment earlier about compression, yes the 19 was different than the 17 at least on the early engines.  the early pistons had valve recess for intake valves and later they went to flat piston and changed head and camshaft.  I am putting a 19 together right now with parts from Norm we got about 3 years ago.  early head and cam.  new pistons are flat but exact same height, so we had a valve relief machined in to match old pistons instead of changing head and cam.  I discussed this with Don(MO) before he passed so hoping to be good to go.  we also bought arp head studs and fire rings from Mack.  the agco fire rings are a steel gasket material sandwich.
Edited by CAL(KS) - 14 Aug 2020 at 8:57am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2020 at 11:12am
It is a wd45 hydraulic system. I got a d17 head gasket and it worked
perfectly, it runs just so nicely.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2020 at 11:28am
ah yes,  all then engine talk i forgot it was in a 45  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2020 at 2:55pm
If you hang a tank on the outside of the right frame rail and have the bottom of it level with the bottom of the torque tube sump and run a hose as large as possible between bottom drain plugs of both and have a good breather on the tank, it would work.
Joe DeLisle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe DeLisle Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2020 at 5:54pm
D-19 diesel pistons have valve reliefs milled in their tops,
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2020 at 10:59pm
It now has a slight miss to it. Don’t think it’s air in the lines cause I cracked injector lines open and closed them (it would be like a gasers distributor cap being not quite lined up)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2020 at 7:50am
On your cooling system, if you added a Thermostat in the system, you can slow the coolant down so the Radiator has a chance to do its job and cool much better. With the Thermostat out, hot coolant from the engine comes out quickly, rolls through the Radiator quickly not giving the Radiator a chance to cool things down before it re-enters the engine. The radiator is a heat exchanger. Hot coming out and hot going back in doesn't make cool. The higher the Thermostat, the slower you move the coolant which gives the Radiator more time to cool things down a bit. Especially when its working in the field....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 10:51pm
Ok thanks Steve!!! Now the traction booster leaks and I got all the        o-rings for it but not sure how to get it off to put them in. Now this probably sounds like dumb question but I haven’t worked to much on these older Allis. The picture isn’t of mine but it is the same setup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2020 at 10:41pm
Got a mower for it, an Allis Chalmers 160 rotary mower although it blew a tire on the way home and has barbwire wrapped around the blade.
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2020 at 8:54am
Nice score!I see it has the optional shredder blades on it.Do you have a not so close up pic of it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2020 at 9:44pm
Here’s a full picture of it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2020 at 9:47pm
Have to put new seals in it but it shouldn’t be that bad to do.
The barb wire tore the seal up so another good project to get done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2020 at 6:43am
55,
Looks heavy duty. At my age I would be adding a jack to that unit.
Loos solid and not all rusted out.
