Oil leak question
Aaron123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aaron123 Quote  Post ReplyReply Direct Link To This Post Topic: Oil leak question
    Posted: 30 Apr 2020 at 4:49pm
I have a 1954 Allis Chalmers WD45 and I have a oil leak where the governor tod goes in side the housing. Any idea what it will take to fix this? ?
I was wondering if any one knows how I can fix it? ? Please see pictures
Edited by Aaron123 - 30 Apr 2020 at 4:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aaron123 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 5:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 5:29pm
There is an oil seal that is shot. There is a brass bushing that is worn out and loose. And the lever/shaft probably has a worn groove in it. Remove hood and radiator to repair.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2020 at 8:28am
Aaron,
I did replace that seal and bushing on the governor cross shaft on one of the WD tractors. Made a special puller to slide hammer the bushing out of the tube.
Did have the entire front timing cover off at that time. May have had to hone it a little due to pressing the bushing back in???
There may have pictures somewhere on here??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aaron123 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2020 at 8:18pm
I have never had that apart I have only owned the tractor for 3 months.
I just might live with the oil leak sounds like a lot of work to do it the proper way by taking it apart.
Thank you for your help guys.. I just had the hood and radiator out to be recore too lol now it is all back together and I see the oil leak.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2020 at 8:27pm
so that means the bolts will come out easy now and the hoses will slide apart
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2020 at 9:00pm
"I just might live with the oil leak sounds like a lot of work to do it the proper way by taking it apart."
Nice attitude.  If it's too hard to do, don't do it?  That's not going to get you far in life.  Do you think it is going to get better by ignoring it?  You bought a tractor, now you have to grow up and fix it.
Sorry for the rant, but that attitude pisses me right off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2020 at 9:43am
With the wear I see in the governor arm, an oil leak is probably the least concern. When the weights let go inside, you'll have to pull the front cover off to replace the cam gear, so you might as well wait till then to fix the leak. (sarcastic font, unavailable)
Edited by CTuckerNWIL - 05 May 2020 at 9:43am
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2020 at 10:34am
This is an issue I have planned to confront when, (and if), I overhaul another 45 engine. I may go through a timing cover and have it ready to go, will document the process with pictures on here.
The engine I rebuilt for my NF 45 has a small leak from the left side governor shaft. I would like to fix it but due to the difficulty of changing the cover, going to live with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aaron123 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 6:12pm
Ok thanks
This page was generated in 0.445 seconds.
