1 gate, need 2 different locks |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78231 |
Posted: 24 Apr 2020 at 3:28pm |
We were the OWNERS of one gate.. Had 10 other gates so we could not SHARE a key and did not want to have a DIFFERENT LOCK on one gate... Another crew, lets say RENTER, needed access thru this gate to get to his property... We also had a CONTRACTOR on site who wanted THEIR KEY as all 10 people on the crew had THAT KEY... Then there was the Electric Company, same thing.. they needed access and ALL their workers HAD THE SAME KEY..............
so 4 different locks... used 8 inches of chain between each of two locks to form a circle.. Chain was not long enough in the end to connect any other way..
Jim.ME
Orange Level Joined: 19 Nov 2016 Location: Maine Points: 937 |
If there are multiple key holders for one lock you can almost be certain you will need to find "Not Me" to educate him, at least that was who I always had to look for when the gates were locked wrong. Also it is interesting the effort that some put into locking a gate wrong, compared to simply locking into the lock on the loose end. Had one (luckily not one of my crew) that managed to get 4 other properly chained padlock shackles captured in the shackle of his lock, owner was PO'd. Two chains just long enough that the number of locks needed must be there to make it reach is worth a try, any extra chain and there is a 99% chance someone will screw it up sooner or later.
iowallis
Silver Level Joined: 04 Jun 2017 Location: North Iowa Points: 325 |
Thanks for the ideas. One of my issues is the gates swing and meet in the middle and I need to wrap the chain around the 2 ends to hold the gate tightly closed as as they try to swing open and stay open so you can drive through. If I had 1 gate and it latched to a post or something more solid I would have other options. Going to try the 2 chain idea, maybe with some scrap garden hose if it will fit as suggested by jaybmiller and see how that works.
Edited by iowallis - 24 Apr 2020 at 7:44am |
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29780 |
Another Alternate a friend of mine uses is allow TWO lengths of chain bolted to the post with One lock of Your choice on one chain to chain opening and allow the others to use the Other opening for ALL their locks. Dope screws that up you can still open yours and remove theirs. Point taken with previous post, note which is the offender and refuse them access until they can learn how to do this.
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21640 |
Ok, I might have an easy, kinda fool proof cheap solution.... Cut a length of clear vinyl tubing and slide it over the chain, tierap or tape so ONLY 1 link at each end is exposed. That way locks can ONLY connect to each other. It 'should' be OBVIOUS to even a neanderthal HOW to lock the locks....maybe... at the every least dang hard to skrewup... |
desertjoe
Orange Level Access Joined: 23 Sep 2013 Location: New mexico Points: 13362 |
Hey Micheal,,it good to hear from you,,,you gotta check in more often,,,we need more story tellers,,,,, Yeah,,I can see where that design will work great as you have to remove a lock before the main pin can be slid out of its place,,,,,, All the ones I seen down in East Texas was on a flat piece of horizontal 1/4" plate steel I just remembered another thing I seen in East Texas was a drive thru gate system that you could drive up to a cattle guard looking thing and move forward till the trk's front tires stepped on a plate that triggered a big spring kinda like a big garage opener spring would start to unravel,,,and it would open the gate,,you had to move on thru as there was so much "time" before the big spring started to unwind and start closing the gate. Worked slicker than chit,,!!!! Them Texans got some good engineers,,!!!
LouSWPA
Orange Level Access Joined: 11 Sep 2009 Location: Clinton, Pa Points: 24063 |
I guess my first question, if I understand this right, is, cant you tell who's lock has been unlocked and not returned properly? If so, the simplest answer is have a talk with the offender |
I am still confident of this;
Michael V (NM)
Orange Level Access Joined: 12 Sep 2009 Location: NM Points: 2351 |
This is the kind I've seen |
Wes (VA)
Orange Level Joined: 12 Sep 2009 Location: Elkton, VA Points: 510 |
Googled for oilfield gate lock, pretty neat ideas there.
Michael V (NM)
I've seen them oilfield locks in the Permian basin (Midland/Odessa/Hobbs),, I had to get out and look, they are simple,but effective..they have a spinning wheel with holes that the locks are in, when the lock is removed, the gate latch will slide thru that hole and open the gate,with the lock in place, the latch will not fit through the hole..
desertjoe
I made a sketch of one with 7 locks on it and I been lookin thru my stuff from that job,,but ain't fount it yet,,,I'll keep lookin for you, tho,, , The beauty of that design is that NOBODY ever forgot to lock up behind them,,,cause everybody would know who dunnit,,,
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3319 |
i still want to see this oil field thing
farmboy520
Orange Level Access Joined: 22 Jun 2016 Location: Beason, IL Points: 553 |
I think the key to making it successful is to make the chain just long enough that it works only one way. Even with the locks locked to one another, if the chain is just long enough for that then they can't get the chain locked any other way.
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
Jim.ME
He might in his case; what I described is the arrangement for access to a number of remote sites I have worked at over the years. As a contractor we had to add a lock to the chain for our crews to enter and had to remove it when the job completed. For security reasons we were not allowed to have the utility, or owner's key, as they used that same lock/key set at multiple locations. And yes something as simple as always locking the lock you opened into the next lock to make a single link chain seems to be too challenging a task for some to complete properly. We also had to give our client contact a copy of our key in case someone on our crew locked wrong. Differences in gates, and how they get secured, makes it hard to figure out how to prevent this problem.
hmm, I was thinking iowallis was supplying the locks...not the others..
Jim.ME
Utilities, and some others, generally use a common lock on their facilities for access of their employees. They don't want to give that key to the general public and it isn't practical to distribute a bunch of odd keys for various sites to all their employees who might need access to many different sites during an outage or such. And I don't think joe public should have a key to a substation, etc.; which is what would happen if the utility's key was given out. |
DT74 has the simple, easy ,almost goofproof solution.... 1 lock, many keys.... There's no reason for different locks, as all need common access. The trick is to NOT have THAT lock to be keyed alike with YOUR personal locks around the farm.... Also... hide a spare key,in a waterproof container,say under a bunch of rocks, just incase 'someone' forgets his key...... |
iowallis
Then I would need to get a lock and have 6 or 7 keys made every year. Plus hunt down the utility company to give them their new key. The combination lock gets switched out every year and the keyed lock stays. Probably make 2 short chains and try that method. Edited by iowallis - 23 Apr 2020 at 5:29am |
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50705 |
Weld 1 end of chain, to 1 lock, then weld the other end, to the other. make it just short enough so that you can only lock 1 lock, to the other... I have never lost faith in the stupidity of any man...
dawntreader74
Orange Level Joined: 28 Oct 2013 Location: Manteno Points: 1761 |
whats wrong with 1 lock' an have some keys made.
Dont lock the locks together.. We have two pieces of chain 18 inches long... Use one lock to lock ONE END of each chain together.. Use the OTHER LOCK to lock the OTHER ENDS of the chain together.. You cant screw that up !! ............ that makes a LOOP that goes around two posts... If you want to go from post to post, then take 3 chains a foot long, connect as chain - lock - chain- lock- chain ........... then attach the END chains to the post PERMANENTLY.
BEEN THERE , DONE THAT........ we had 4 LOCKS ! Edited by steve(ill) - 22 Apr 2020 at 9:30pm |
HudCo
desert joe you have my attention sometimes well most of the time the simple things are the hardest for me to see
desertjoe
Well,,I'll tell ya'll a fail safe method that I seen down in East Texas where several different oil field companies had to have access,,, It was something welders made that could have as many as 6 locks and you only had to unlock yours and all the other locks stayed locked. I'll bet ole Ken down to "Hennessy" has seen those locking systems I'm talkin about. Every gate that had a gas well on it had this locking arrangement. Very simple but almost fool proof,,,,,
JW in MO
Orange Level Joined: 16 Feb 2010 Location: South KC Area Points: 2598 |
We use the two lock method at our show grounds for the power company and members with no problems so far but now that you brought it up, guess what I'm going to prepare for? We do have the chain lag bolted to the post so it can only be used in one spot. The only other suggestion I would make is take the two locks and weld the swivel sides together, either at the base or toward the top of the shakle
Hubert (Ga)engine7
Orange Level Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6152 |
Dave, you can't cure stupid but your suggestion comes close. One other solution is to use 3 short pieces of chain and place a lock between two of the pieces. They will need to be short enough that it will take all three sections to wrap around the gate. Maybe they won't screw it up.
Lock the locks to each other and to the chains at the end of the lock set, open any lock and chain is open regardless which one is opened. Instruct the Dopes as to HOW to lock them together, include a photo, they fail to do that and stop the program make them all find some place else to play. INCLUDING the utility, they are the ones that taught me that process.
Edited by DMiller - 22 Apr 2020 at 7:58pm |
iowallis
I need to have 2 different locks on it, a keyed lock for me, the person who farms the ground, and the utility company and a combination padlock for the people who hunt the grassy and wooded areas that I switch out every year. As of now I hook the locks together so unlocking one will unlock the gate and leave the other lock locked. Inevitably (3 times so far) someone will not lock the locks together but lock the ends of the chain and leave one lock hanging on the chain and that lock, when unlocked will not open the gate. Is there a type of latch (lack of a better word) that would allow 2 different locks yet allow the gate to be unlocked by only unlocking one lock?
