WD clutch pedal |
Huolti
Bronze Level Joined: 03 Sep 2017 Location: Alberta Canada Points: 34 |
Posted: 03 Apr 2020 at 8:21pm |
Restoring a WD and trying to get transmission clutch pedal off to put bushings in. The pedal won’t slid off as the tractor frame is in the way. Any suggestions?
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8167 |
I believe you will need to remove the lock set screw on the brake side of the cross shaft and push/drive the cross shaft back through the tractor towards the brake side. That should allow you to then remove the foot clutch pedal.
Regards, Chris
Huolti
Didn’t realize that was possible. I will try that. Thanks
Lon(MN)
Orange Level Joined: 11 Sep 2009 Location: Elk River,MN Points: 1905 |
I always replace the shaft and bush the brake pedal also.
Ed (Ont)
Orange Level Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1218 |
New cross shaft is available at steiner tractor parts and you will have to rebush the 2 pedals.
Huolti
Thanks every one got it off quite easily and going to replace or repair.
Sugarmaker
Glad you got it out where you can look at it. I have repaired the shaft and the pedals both. Putting a bushing in, and getting a new shaft is the right way. Sometimes I don't color inside the lines very well!
Regards, Chris
59f100292
Bronze Level Joined: 11 Dec 2011 Points: 63 |
I need to rebush my pedals, and hand clutch also if thats an option. Are they a brass bushing? anyone happen to know what size I should look to buy?
Sugarmaker
I think most folks have brass bushings installed. I would check the shaft wear fires and determine if it is ok or does it need repairs too. Get that to a nominal size first. McMaster Carr has many bushing options, They are reasonable in price and quick delivery too. You may need a machine shop to bore the parts for the bushings to be installed. Its was rewarding to have nice tight components like hand clutch, foot clutch and brake pedals too!
Regards, Chris
