303 oil |
Post Reply | Page 12> |
Author | ||
Stanley
Bronze Level Joined: 16 Oct 2009 Location: PDC, WI Points: 188 |
Posted: 02 Apr 2020 at 10:23am |
I have used the 303 oil in hydraulics and tranny of D-17 series 1, WD45 & 7030. Also in a AC 6140.Members of this site do not reccommend the 303 oil. What is wrong with the 303 oils? We do not use the tractors for farming. Mainly for brush hogging & sno plowing.
Sponsored Links | ||
Orange Level Access Joined: 12 Sep 2009 Points: 19543 |
"303" is an oil spec, which started with the 4010/3010 John Deere in 1961. Todays oils, 821-821XL-Permatran, etc have evolved to a much better oil for todays wet brake and transmission clutch pack designs. I think the tractors you have will get along just fine with a good quality "303" oil.
Michael V (NM)
Orange Level Access Joined: 12 Sep 2009 Location: NM Points: 2335 |
303 prolly ok for the '45 and '17, I would NOT use in the 7030 and 6140, there are additives, different refinements in the oil for the later tractors, use a 821 spec oil in the 7030 and 6140, prolly will save some hydraulic/trans/rear end/PD/wet brakes serious problems...
Now, remember...…..A 3020/4010 had wet brakes and closed center hydraulics. That's why 303 oil was invented.
Michael V (NM)
yea Dr.,, I remember,,and it was made from sperm whales , even JD has upgraded their recommendations...
Stanley
Thanks for the info
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7946 |
Here's what I use in the One Hundred Series,, seems to work great!
Edited by DougG - 02 Apr 2020 at 8:08pm |
FREEDGUY
DougG
Thanks(1)
Grrr the pic didnt go through,, its Extreme Pure Flo,, yellow bucket , good stuff
Edited by DougG - 02 Apr 2020 at 8:26pm |
FREEDGUY
Thanks
truckerfarmer
Orange Level Access Joined: 26 Jan 2013 Location: Watertown, SD Points: 3179 |
Hey, I like that bucket! Never seen one with a handle on the bottom.
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50547 |
Gary Burnett
Orange Level Access Joined: 11 Sep 2009 Location: Virginia Points: 2853 |
Yea I wouldn't use that 303 stuff from TSC to oil a chain with much less use it in a hydraulic system.Its very cheap for a reason.
TimNearFortWorth
Orange Level Joined: 12 Dec 2009 Points: 2014 |
Started with Mystic(s) at TSC in early 2000's.
Spoke with an ex-A-C mechanic that ran/recommended Schaeffer products in pullers he built/ran of his own but he felt strongly that Traveller brand from TSC was good enough for all of the old D-Series that I ran. Showed be some units he had torn down for repair and some brought in for re-work to be made into pullers, most using the Traveller brand as TSC was putting more stores in. Never had an issue with Traveller brand myself and for 5-10.00 more a bucket AND with 821 spec on the bucket, have no reason to even try 303. Most of my (12 total) units have leaks and a fair amount of hours so see no reason to buy the high end stuff from JD or Case-IH. Just my opinion but no plans to bring a bucket of 303 home, no matter how cheap the price . . . .
JC-WI
Orange Level Access Joined: 11 Sep 2009 Location: wisconsin Points: 33652 |
Back in the 70's when we got the 170, we bought Havoline oil from the Texaco company or the DX brand of oil and the delivery man had oil that he recommended and that was the 303. Had no problems with it, summer or winter. Then the local farm co-op mill bought out the Texaco dealer for his truck, tanks and costumers... and soon were selling FS/Farmland fuel and oil. So we switched to their recommended hydraulic oil, 'quicklift' and used that for years. The Co-op's diesel fuel was reformulated and had cleaning additives and our tractors started smoking and lacking power...changed out the fuel filters and they would run better for a short while. Finally put a filter on the tank and third change of filters on the diesel tractors which ended the lack of power. Guess the main barrel was getting cleaned too from the old diesel fuel residues that had settled out over the years. Back to the hydraulic oil, the Co-op got high priced on their quick lift oil and I bought Farm&Fleet hydraulic oil, much cheaper and had the same body weight, pour ability and spec'ed out better than the quicklift, so used it for years and they went up in price. One day I was at tractor supply and seen 303 oil in the yellow pails and I thought back to the 303 we use to use and bought several pails of it and changed out the loader tractor hydraulic oil and filter. I had noticed the oil flowed a little thicker than what I remembered the original oil did and thought it wasn't 'diluted' as much with lighter oil additives ... yea, come winter, and got down to 10 above, the tractor started harder and at 10 below, the 170's pump was leaking out through the end plate gasket. Ran it until there was a warmer day and the tractor was warmed up I drained it and put the F&F Universal tractor hydraulic oil in and a new filter, the pump quit leaking and tractor started easier even in the -30 cold. Used up the rest of the 303 in the D17 tractors since they didn't usually get started in the winter. Later I read on the side of the TS 303 pail that it was 'reconditioned' oil. The original 303 oil years back was not reconditioned oil. That's my story and experience of 303 oils.
Lonn
I remember some 303 oil being sold a few years back that was not made to spec. Don't know what brand.
Wink I am a Russian Bot |
FREEDGUY
What's your "engineering/mechanical" PROOF of why it's cheap for a reason ?? What kind of chain are you talking about BTW ?? We've been running the "yellow" bucket for 20 + years with NO ill effects ??
Edited by FREEDGUY - 03 Apr 2020 at 6:22pm |
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7997 |
Rural King used to sell 303 and 821 spec'd oil both in "yellow" buckets so you had to be able to read the label. Don't know what they are selling today but know they have a range of brands and types. Currently have Traveler 821 spec from TSC.
JohnColo
Orange Level Joined: 03 Apr 2020 Location: Niwot, CO Points: 1258 |
I was using 303 in most of my stuff then read somewhere, perhaps here or another tractor site that is wasn't to be used on machinery built after 1974. I think it is 20 wt oil, it says right on the 303 bucket that is shouldn't be used in machinery built after '74. The premium oil TSC sells for around $40. for 5 gallons is 10/30 and is good for all the current machinery. I've got a couple buckets of 303 in the shed which will probably be used in the older tractors, such as most of my AC's
Alex09(WI)
Orange Level Joined: 15 Mar 2012 Location: CECIL WI Points: 1698 |
I used to use 303 hyd oil, but changed to the premium oil that meets the 821 spec. Why wait for something to go sideways?? For my own tractors, and for my repair shop, I use the 821 equivilant oil as a preventative measure becasue when something happens, it will be too late.
www.awtractor.com
CTuckerNWIL
Did you read ANY of the article? What’s really inside THF 303 So, what actually goes into THF 303? The honest answer is anything and everything. Because there’s no independent party verifying the content of THF 303s, the sky’s the limit for what types of fluids these products can contain. And that’s a major problem. Often, THF 303 contains high levels of a fluid called flush oil. What is flush oil? On any given day, a lubricants production line may create many different fluids. To prevent cross-contamination between products, the entire production line is flushed with an inexpensive oil between production cycles, removing any residue from the line. The problem with flush oil While flush oil plays an important role inside a lubricants production facility, it was never meant to be used by consumers. Its job is to collect leftover fluids, so once it’s been used, it becomes a stew of any number of chemical elements that were never intended to be combined. Maintaining a tractor’s hydraulic system depends on a finely tuned balance of precise ingredients. But because flush oil doesn’t follow a recipe, there’s no way to control its chemical makeup or its blend of additives, meaning there’s no way it can truly protect your equipment. Time is running out for THF 303 manufacturers Recently, states have begun cracking down on THF 303 manufacturers. In multiple cases, government regulators found that THF 303s fail to meet their claimed specifications. What’s more, these regulators have found that THF 303s are so underperforming that equipment damage is likely to result from use. Because of their fraudulent claims, the sale of THF 303s has been banned in several states. As the truth about these defective products continues coming to light, many industry experts agree it’s only a matter of time before THF 303s are banned nationwide. |
fourthgeneration
Bronze Level Joined: 03 Jan 2017 Location: ohio Points: 170 |
Most 303 have flush oil in them I would only use 303 to start brush fires myself. Some states have banned the sale of 303 for being fraudulent.
Edited by fourthgeneration - 03 Apr 2020 at 11:44pm |
exSW
Orange Level Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
I've just quit cheaping out and buy Hytran. Yes it's expensive but you know what you're getting every single time.
Learning AC...slowly
FREEDGUY
No, I never read any of the above "propaganda". Let me guess, you don't use Wal Mart oil either??
Edited by FREEDGUY - 04 Apr 2020 at 5:50pm |
CTuckerNWIL
I haven't used Walmart oil, because I have enough Farm and Fleet oil here to last me a decade. There is no "propaganda" in that report. Just the facts about where the flushed oil goes, and what might be in it. As long as 'they' can sell their uncontrolled waste oil, they will sell it, solvents and all. |
Jim.ME
Orange Level Joined: 19 Nov 2016 Location: Maine Points: 937 |
Feel free to run what you want, your machine, your choice. The original 303 used sperm whale oil as a key ingredient. Sperm whale oil is no longer available, so how can it be meeting the original John Deere 303 spec ? I choose to use an oil/fluid at least stating it meets manufacturer's current specs, even if I don't purchase the manufacturer's house brand.
Here are a couple more articles about the 303 issue. PQIA_Bulletin_08-21-2018-B1.pdf Perilously_Obsolete__The_Dangers_of_303_Tractor_Hydraulic_Fluids.pdf |
Gary Burnett
After reading up more on the 303 don't think I'd chance soaking an axe head in it to get the rust off.(LOL)
DougG
The super cheap stuff is junk for sure - Extreme Pure Flow and others with better quality stanards are good to go in the 100 series etc
wlambs
Bronze Level Joined: 18 Jun 2018 Location: ga Points: 67 |
used in my tractors but was told no longer made as of aug of 18
185,6080,6060,72 allcrop, roto baler
chaskaduo
I believe 303 is banned in Georgia, Missouri, and North Carolina at this time.
