4020 3pt leaking
Jess View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jess Quote  Post ReplyReply Direct Link To This Post Topic: 4020 3pt leaking
    Posted: 19 Aug 2010 at 9:41pm
I know its green but my budy has one and he keeps putting new seals on the 3pt shaft i thought there is a fix for this but can not remember if anyone knows or can send me in the right direction it is greatly appreciated i told him to just get an orange on but his grandpa bought it new Thanks Jess
joshjohndeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2010 at 9:43pm
are you referring to the load shaft seals on the bottom of the axle housing and which style is he putting in the tractor?  also has he replaced the bushings and load bar if u dont they will leak everytime.
Jess View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jess Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2010 at 9:51pm
yes thats it not sure which style how do you tell which one is better
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2010 at 9:59pm
some of them had a steel bushing with an o-ring inside of it others did not they had a bushing pressed into the housing and then u pressed in a double lip seal that went backward of what u would think it should by looking at it. however i had 4010 that wouldnt quit leaking so i put in the o-ringed bushing with the double lip seal on the outside of it. has he replaced the bushings and load shaft?
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2010 at 10:04pm
also if he is doing this himself before he removes the load shaft from housing make sure he puts the load draft lever under the seat all the way up in the load position other wise he will cuss himself later trust me i watched a guy do it aside from being difficult to remove the shaft u have to take the rockshaft housing off to fix it and thats alotta work that can be prevented.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2010 at 10:25pm
THe magic words are Boling Machine. http://www.bolingmachine.com/
Gerald J.
FHOliver View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FHOliver Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2010 at 11:05pm
T. H. E. has what I think you are after. its in the 2010 catalog which you can find on line at www.the-co.com     look under hitches/front ends section 3-31 top of page.  new bushings with an internal o ring for 20 bucks each  and new load shaft for 59.95.  I haven't used them personally but have heard they work. Ive got many hrs on a 4020 most of them plowing contour strips in wisconsin, take good care of her. good luck frank
This page was generated in 0.081 seconds.
