7050 glass fuel filter |
Post Reply |
DIESEL
Silver Level Joined: 26 Aug 2013 Location: Sandhills Points: 259 |
Posted: 17 Feb 2020 at 10:33am |
Would anyone happen to have a filter number for a 7050 glass fuel filter, I need a number to reference one from Napa. Thanks
Acdiesel
Orange Level Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2513 |
NAPA number is a 3370
D19 diesel,D17 diesel SER.3 D14 NF,D14 WF, D15 SER.II wf
D15 SER.2 DIESEL,D15 ser.II nf D12 SER.I, D10 Ser.II 2-720'S Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
Lonn
Orange Level Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29773 |
Is it supposed to be glass? The dealer has always handed me the steel one.
Wink I am a Russian Bot |
Hurst
Orange Level Joined: 11 Sep 2009 Location: Midway, Ky Points: 1201 |
They can be interchanged in most instances. The glass is rated at a lower pressure than the steel, so that must be taken into consideration if there is a pump before the filter. I've had both on my 7000 over the years, just depended on where I bought it. Also, some people seem to be cautious of using the glass filters on combines, thinking they are a higher risk of fire. A metal should be able to be used anywhere a glass was used, but a glass cannot necessarily be used where a metal one was.
Hurst
1979 Allis Chalmers 7000
5800 Hours |
Lonn
Yes I've used both over the years. I trust the steel one more but my 7050 has no pump before the filter so not a big worry. My L2 has the spin-on but uses a glass water separator that is not really a so-called filter. Just wondering what was correct for my 7050. Doesn't really matter I just use the steel ones now and have a couple on the shelf at all times.
Orange Level Access Joined: 12 Sep 2009 Points: 19590 |
The glass fuel filter (not the glass water separator) was replaced by Allis-Chalmers 40+ years ago with the metal fuel filter. This was because on some (not all) engines the hand primer actually pressurized the filter and it could explode. I still have a scar on one of my fingers from one of those happenings. The glass water separator was always downstream from the hand primer, so that wasn't a problem. The glass water separator and the fuel filter do not and will not interchange as the filter bases are ported different.
DIESEL
I went with the glass filter Acdiesel gave the number for, it is located before the pump.
Post Reply | |
