JB WELD |
nella(Pa)
Orange Level Access Joined: 11 Sep 2009 Location: Allentown, Pa. Points: 3081 |
Posted: 02 Feb 2020 at 5:13am |
A few weeks ago there was a discussion about JB Weld. Someone thought that another product like it was as good or better. Dose anyone remember the name of it?
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50529 |
Thanks(1)
belzona 1111?
desertjoe
I've used both and have good luck with Belzona as it is easier to machine. They both have a temperature limitation fo bout 500°. There is a JB weld "extreme heat" that is good to upwards of 2000°,,,!!! It must be special order stuff as I've never seen any around here..
shameless dude
don't Permatex make something like that too?
desertjoe
I have not ever seen any Permatex product but there sure might be,,,,actually,,,if you needin some patch material for where you need some heat tolerance,,,the JB Weld Extreme heat looks like the best,,,,, HMMmm,,,gonna check out Amazon see what they got,,,,
Fred in Pa
Orange Level Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9102 |
All depends on want u are using for.
HD6GTOM
Dog gone it, I have never seen anything of these products, except plain old JB Weld. Guess I'll have to ask next time I'm at NAPA.
tadams(OH)
Orange Level Access Joined: 17 Sep 2009 Location: Jeromesville, O Points: 9640 |
I have used PC7 it works and comes in 2 parts and you mix them together, it's solider and used it on sand stone monuments so it takes all kinds of weather. When I used JB Weld it wouldn't take the freezing weather
chaskaduo
I have used PC7 also. Good stuff Maynard.
JW in MO
Orange Level Joined: 16 Feb 2010 Location: South KC Area Points: 2595 |
Sorry to hijack but, chaskaduo, where is the Maynard from? I've heard and said that for as long as I can remember but don't know origin. Oh, and I have used Lab Metal from Fastenal as a filler, not an adhesive.
truckerfarmer
Orange Level Access Joined: 26 Jan 2013 Location: Watertown, SD Points: 3178 |
Gonna take a stab in the dark and say it's a reference to Maynard G. Krebs from Dobie Gillis.
shameless dude
yep
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21467 |
DEVCON make a lot of it ! I know the steel epoxy will seal a gas tank that a hachet made an 'inspection slot' in it.......
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4352 |
Thank you Jay. I knew there was another brand my local engine machinist guy had me looking all over for 25 years ago. His way or the highway,cause he can work wonders if he wants to help you. But don't ever expect much if don't follow his advice all the way. Don't know if it was worth the effort as it was only a JD put put. If Oh Shameless ever comes and visits I can fill him up on Black Label and let him express his anger on the popping johnny.
chaskaduo
I watched Dobie Gillis when I as a kid.
Darrell G (MN)
Orange Level Joined: 11 Sep 2009 Location: Green Isle MN Points: 1496 |
I have used Lab Metal, however it must be very clean, they also make a high heat version and I used it to repair an exhaust manifold two years ago and it's still holding
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4768 |
I use the permatex/loctite epoxy mixer cups regularly. They come 10 in a can, and are part number 21425. Once in a while I get an old batch, one part or the other is dried out. I've been using this stuff on Roosa pilot tubes for years. It used to be marketed by Caterpillar as well, which is how I learned of it. Cures much faster than traditional JB Weld, and JB Quik wasn't good enough for pilot tubes.
