170 Fuel Line Fittings |
Mapleshade
Bronze Level Joined: 08 Jan 2020 Location: Castleton ON Points: 4 |
Posted: 09 Jan 2020 at 11:25am |
I have removed
the fuel pump on my 170 diesel because it was leaking fuel out the lower
fitting and oil out the gasket. I will be putting on a new pump and the line from the tank to the pump but am confused about the proper line
fittings. The old line is copper and has just a single flare at the end. There
is a rubber piece between the flare and the nut. At the top of the fuel pump
the fitting has what looks like a furl on the line with the rubber and then the
nut. Neither line looks right to me. I have searched but can’t find any photos
or info. Can anyone clear this up for me? My other 170 is gas and it has normal
double flare ends on the line. |
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7946 |
That's how most are put together, I'd replace the rubber pieces as they crack and leak air, go to a diesel shop tho , .30 cents compared to Agcos $4.25 a piece!
Mapleshade
Doug thanks for the reply and the info on a diesel shop. I went to a diesel expert a couple of towns away and he graciously gave me his time, advice, a bunch of the rubber seals and a couple of fuel filter housings. The threads in one of my housings are not great.
Barry
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8033 |
Yeah those lines have a slight swell on the end and a rubber ferrule under the nut. They actually work quite well.
