200 allis charging issue
K bockting View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K bockting Quote  Post ReplyReply Direct Link To This Post Topic: 200 allis charging issue
    Posted: 07 Dec 2019 at 7:15am
Installed rebuilt alt and new reg. Wiring and anmeter look ok. Only getting 12.5
on load tester at batteries. Anything else to check?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2019 at 7:36am
Turn on all your lights and after a while check again
If the batteries are fully charged the alternator won't charge them more. Do your batteries get weak and if so do you still only show 12.5 volts on your volt meter when running? You're using a hand held fluke meter or equivalent. I've had trouble with a cheap load tester
Edited by Lonn - 07 Dec 2019 at 7:43am
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2019 at 7:43am
Make sure the Regulator is properly grounded. Sounds like improper ground at the VR. With "DN" series, or external regulated Alternators, make sure the Alternator case is grounded also. If the Tractor was freshly painted, paint is a great insulator.... HTH
Steve@B&B
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2019 at 8:15am
Be sure to verify you have the correct regulator. I got the wrong one from AGCO and after replacing all the wiring and it still not charging I went back and found they sent the wrong one.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
