ENGINE ROTATION ?? |
Author | ||
FREEDGUY
Posted: 15 Nov 2019 at 5:51pm |
Was just thinking today as watching the 10+ inches of snow melt off of the corn, what determines the rotation of a 4 stroke engine ?? Is it the starter that drives the crank in a certain direction ?? Can a 4 stroke engine able to be oriented to run in the opposite direction like an electric motor,or are there issues with oil/water pump drives ??
Like I said,just wondering.
Sponsored Links | ||
weiner
Orange Level Joined: 19 May 2012 Location: Cadillac, Mi. Points: 4305 |
Certain twin engine airplanes, each engine rotates the opposite direction to counter act the "P" factor. I think that is what it was called, been 35 years ago. I`m sure certain things were changed. Camshaft, magnetos timing, I can`t visualize stuff like that any more. I think I`m getting a headache,
Real heros wear dogtags, not capes.
FREEDGUY
seems like i heard a story about a blown engine in an inboard boat (GM?) that got replaced with a scrap yard engine out of a vehicle and the transmission blew out because of the wrong rotation ??
Michael V (NM)
Orange Level Access Joined: 12 Sep 2009 Location: NM Points: 2335 |
the 2 stroke detroit diesels can be made to run opposite direction,,but hafta turn a lota stuff around, camshaft, balance bars, etc,,,
IIRC there was some multi-engine tractor pullers that ran opposing engines the other way to offset the torque twist,.... yea,,, it can be done,,,as they always tole me, speed =$$$,,,just how fast do you want to go as far as mechanicals,,,,yea,,,gotta change the cam, oil pump, ignition,,, and whatever else.....
SteveMaskey(MO)
Orange Level Joined: 11 Sep 2009 Location: Wellsville, MO Points: 589 |
The Fairmont railroad engines would run clockwise or counter clockwise
Dakota Dave
Orange Level Joined: 12 Sep 2009 Location: ND Points: 3894 |
Two strokes are relatively easy to run reverse rotation. Aircraft and boat engines run reverse rotation with a cam and mag change. If you turn he engine backwards with out changing the cam it will suck in the exhaust and blow out the intake. Changing the rotation of the starter is easy.
DanWi
Orange Level Access Joined: 18 Sep 2009 Location: wttn Points: 1705 |
When they run Allison aircraft engines on pulling tractors they can have one running each way.
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21486 |
Them old 2 strokes on golfcarts go 'bothways', they just spin starter CW or CCW to get the cart to go FWD or REV .
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4366 |
True confestions I coast start my old D6 Cats if I shut them off at lunch time if there is a hill in the right spot.They had a revearser lever way back before any wheel tractor. But anyway if its not much of a hill I let it coast a little to make sure it will roll,and then I back up to get as much hill as possible.
Anyway I have forgot to put it back to forward twice in 50 years. But there is no mistaking what you have done. Oil came blowing out of the wet air cleaner, the second time was dry air cleaner. But what a cloud of dust. So you tend to grab the throttle and shuter down so I never tested how long it would run backwards. But a old Cat 318 sure as heck will.
DaveKamp
Orange Level Access Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5639 |
The four stroke engine's FIRST AND FOREMOST factor, is camshaft timing. After that, the oil pump, coolant pump, alternator, and magneto (if it has one) needs to be addressed. Distributors are oftentimes okay, but sometimes reluctor wheels (electronic) or breaker point pivot position will cause them to operate slightly different than in the other (like... wear faster, or be less-stable). Counter-rotation in propeller driven airframes and boats is done for dynamics and efficiency reasons... and it's easy to describe: I have a 17 foot runabout with an inline six that is FAR from stock. It swings a big propeller, with lots of pitch, and basically no rake... it generates lots of thrust at very high speed, which happens to be coincident with lots of planing lift- there's very little hull in the water... mostly the drive unit, the propeller, and about a square foot or so of hull for the whole 1500lb boat. The propeller is 'screwing' it's way through the water to generate this thrust, just like an electric drill-driver pushes a deck screw through a plank. For every action, there is a reaction, and just like the drill twists in opposite direction of the screw, my boat is trying to 'lean' in the direction opposite of prop twist. To counteract the force of prop torque, there's a 'trim tab' mounted on the cavitation plate behind the propeller that directs a small portion of the prop wash to one side, which helps at slower speed, but at extremely high speed, I basically have to 'steer' the boat slightly sideways to keep it going in a straight line. And of course, when I grab the throttle and snap it back to idle, the boat reacts by 'snapping back' to straight orientation, and usually a fair lean in the 'opposite' direction. Some of this can be attributed to the engine's spinning mass slowing rapidly, but most of it, is the fact that the propeller's bottom half (in clean, deep water) is pulling one way, while the top of the propeller (at high speed, is ventilated... running in aereated water) is not. the 'sideways' walking is downright aggressive with a very high pitch prop. When docking at idle, the propeller's twisting effect 'walks' the boat to one side in forward, and the other in reverse. We actually use this circumstance to aid in docking, especially on inboard boats (outboard and Inboard-Outboard drives pivot the propeller angle, so they can be 'steered' fairly well in reverse-thrust, so it's not as necessary). Aircraft have exactly the same scenario. When multi-engine setups are used, it is most common that the propellers are set up for counter-rotation- one turns to the left, other to the right, so that the propulsion's natural side thrust of one, will be counteracted by same from the other side. It results in higher efficiency, and improved handling. On many marine drives, the engine is actually mounted 'backwards' in the hull... flywheel forward, and transmission drives off the 'front' of the crankshaft. This is done because the flywheel diameter needs clearance from the bottom of the boat... they tilt the engine, and drive it from the nose, so that the entire engine system can be closer to the bottom of the boat, and more in-line with the propeller shaft. When they do this, they build new oil-pans, relocate oil pump drives, change the camshaft, distributor drive, water pump, etc., so setting them up for opposite rotation is no big deal. Also note that in some marine applications, the engine drives towards the rear of the boat (directly out to the propshaft), while others drive forward to a gearbox, which then drives rearward to the propeller (a "V"-drive). In V-drive systems, it's not unusual for the engine to be oriented with flywheel towards the aft, but driven off the front of the engine. Just depends on the boat. Another option, is to set up the transmission so that forward is reverse, and reverse is forward. On transmissions that use a 1:1 ratio, it's as simple as changing the bellcrank shift lever connection position. On planetary transmissions, the gear ratio for reverse and forward are NOT the same, so it's a more complex task. Many industrial engines (Waukesha, for example) have the option of rotation as a 'natural' part of the design. This is easy to figure out when you're holding the camshaft. If the camshaft bearing surfaces are all the same, AND there's cam-gear mounting on BOTH ends of the camshaft, it is symmetrical... so a reversable engine. To reverse the rotation, just remove the camshaft, flip it end-for-end, reinstall it, reset ignition timing (distributor!) and I THINK... flip the oil pump housing... and you have opposite rotation. As noted, two stroke ported engines will run either direction. They're usually DESIGNED to favor for one direction... the most obvious being piston-thrust-angle. If you place a rod down the exact centerline of the bore, you'll find that the centerline of the crank does NOT intersect it... the piston will be offset to one side. This is to keep the rod thrust angle closer to 90 degrees for LONGER, hence, generating more useable torque through the power stroke. It means that the rod angle is steeper during compression, which has some impact on compression curve. When running this backwards, it certainly will NOT run as well in the opposite direction. Now, there's been a few two-stroke gassers designed to run in BOTH directions... and some were used to run in reverse unintentionally... Those designed to run backwards... as noted by others... golf-cart two strokes frequently are set up to start in reverse, which allows the cart the ability to back up without having to have a gearbox. Really large ships running 'oil engines' (bunker oil, so substantially thicker than diesel, but still compression-ignition) have no gearbox... they start in-gear, and they have direct reverse, but HOPE to never have to use it. The Mercury Mark 78 'dockbuster' was an inline six two-stroke that had no neutral, and no shifting. When you pulled the throttle to neutral, it killed the ignition. When you moved the throttle to forward and hit the button, it started in the forward direction... when you moved it to the reverse position, a cam reversed the ignition (to the opposite side of TDC), and activated a second (reverse-operating) starter. It worked... uh... but not great. On heavy boats, coming into the dock, frequently there was too much drag on the propeller for the starter to actually START the motor, and as a result, the pilot would not be able to control his arrival, the boat would strike the dock. Here's a demonstration of the Mark 78... move to about 0:56 to see it: Now, if you wanted to drag race an overconfident Mustang driver... the best thing to do, is place a pink-slip bet with the following: "I'll drag race you, I get to pick the course, and the rules." When they're foolish enough to agree, you have them meet you at the starting line, and the rules are... six blocks, in reverse. You show up in a Saab model 95... a three-cylinder two-stroke. As you coast up to the start line, push in the clutch, shift to reverse, cut the ignition, flip it back on, and bump the clutch... now the engine is running in reverse. Pop to neutral, wheels on the start line, put it in first. When the flag drops, hammer it, shift through the forward gears, while steering backwards. He'll beat you for the first 20 feet, but after that, he'll be out of gears, and you'll keep accellerating. On a somewhat unrelated note... OMC made a two-stroke 4.5l V8 outboard motor that was rated at 300hp... but due to many factors, was capable of much more, for those willing to invest time and effort... but here's a guy who 'de-marinized' and horizontallized one, mounted it in a car chassis: And if you like silly screaming power, take a laugh at this test drive: Edited by DaveKamp - 16 Nov 2019 at 1:10pm |
john(MI)
It would seem, just putting it in reverse would be a whole lot easier! What do they do to the tractors that are turned around like a forklift type? |
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50547 |
There was one particular tractor, that would sometimes start backwards, I believe it was a hot bulb type, early in the last century, that had a reputation for running the wrong way. Wish I could remember, but it escapes me, tonight. IIRR, it was this tractor, and some other lemons, that played a role in the establishment of the Nebraska test law...
nella(Pa)
Orange Level Access Joined: 11 Sep 2009 Location: Allentown, Pa. Points: 3082 |
You change the bull gear in the rear end to the other side.
nella(Pa)
P factor is correct. |
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7998 |
I've had 6-71 & 8V92 Detroits run backwards when killed and not get the clutch down quick enough. Just let the clutch out and stomp the brake then restart with starter. What surprised me was when the 3406B Cat did the same.
DaveKamp
Lanz Bulldog. https://www.youtube.com/watch?v=pYeEotP_c3M Watch it dance in oscillation (zero RPM) at 1:30 and beyond. It's not a 'reputation' of running the wrong way, it's just a nature of the beast- it can be run either direction. The Lanz was no 'lemon'... they were beastly pulling machines. If the Nebraska test laws had any issue, it would've solely been academic in nature... the only thing the Lanz could do , was select it's PTO direction, or run engine-reverse / gear reverse to get an additional forward range, or engine reverse/gear forward to get additional reverse gear speeds. My cousin has one of these, and he's not a very big guy, so to start one, he gets it oscillating, and lets it warm up that way, then bops the throttle to get it going in the right direction.
Edited by DaveKamp - 17 Nov 2019 at 12:54pm |
FREEDGUY
Thanks for all of the replies, but WHAT makes an engine turn the direction that it does ??
festus51
Orange Level Access Joined: 26 Mar 2017 Location: Osage City, KS Points: 1639 |
I lugged down a Detroit 2 cycle in a dump truck, pushed in the clutch at about the time it was going to die. It started running backwards with exhaust coming out of intake. If you going to runem backwards you do not get oil pressure because the pump is running backwards also.
TramwayGuy
Orange Level Access Joined: 19 Jan 2010 Location: Northern NY Points: 11220 |
The Olivers (66-880) with the Bosch Pump and Diaphragm type primary pump will run in reverse if you can get the engine to turn backwards; like rolling it backwards and put it in a forward gear. It would run that way for a long time, until it seized for lack of lubrication, since there would be no oil pressure.
A lot of diesel engines will do that. So to answer the question, the starter direction determines the rotation. |
FREEDGUY
Thank you TramwayGuy. I was pretty sure "pump" rotation would be an issue, was just curious as to the engineering aspect as to what direction an engine was to spin
Not the Lantz, I was thinking of, Dave. I believe the little devil made by Hart-Parr, is the one I was thinking of, being a 2 stroke, and having the reputation of flipping directions, once it was under full load! OH, and here's your video, when that thing is sitting there, going back and forth, it reminds me of the federal gov't... [TUBE]pYeEotP_c3M[/TUBE]
Edited by DiyDave - 17 Nov 2019 at 6:34pm |
