RADIATOR CAP 715 ac backhoe
copperhead1971 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote copperhead1971 Quote  Post ReplyReply Direct Link To This Post Topic: RADIATOR CAP 715 ac backhoe
    Posted: 19 Oct 2019 at 9:02pm
having trouble finding a radiator cap for backhoe ,its around a 1975 with Perkins engine .
not sure if it is suppose to be a 4 or 7 lbs  the part number i have is 0254891-5 ,any body have a newer part number or where to find one that will work...thanks for any info
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2019 at 12:57am
the replacement cap I got at the dealer for my hd3 weighs twice in my hand what the one on it did from the parts store...........
HD3
Post Options Post Options   Thanks (0) Thanks(0)   Quote copperhead1971 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 9:39am
so is it a 4-6or7 lbs cap?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2019 at 1:10pm
You could go up to 12 PSI if system is good - it shouldn't be heating enough that the pressure will make that big a difference
Post Options Post Options   Thanks (0) Thanks(0)   Quote copperhead1971 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2019 at 9:32am
thanks for the info ill have to look around and see what i can find
Post Options Post Options   Thanks (0) Thanks(0)   Quote copperhead1971 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2019 at 2:45pm
also coke was wondering if you have a updated hydraulic return filter part number ? the original part number is 1009380-5 but can't find any cross part numbers
