B Transmission and Final Drive oil |
BenGiBoy
Orange Level Joined: 11 Nov 2015 Location: Ashville, NY Points: 696 |
Posted: 19 Oct 2019 at 3:27pm |
I have a reprint of the Operating Instructions / Maintenance manual for my B and it says SAE 20 in the transmission and differentials and im thinking of doing a fluid change.
What do you all use? Would 10W-30 engine oil be good for it? I'm thinking probably don't want too thin though, right?
Thanks all... BenGiBoy
'39 Model B
Tractors are cheaper than girls, remember that! |
CrestonM
Orange Level Joined: 08 Sep 2014 Location: Oklahoma Points: 8357 |
I use SAE 20 in mine, but I think most folks use universal hydraulic/transmission fluid.
HoughMade
Orange Level Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 691 |
I use universal hydraulic/trans fluid. If you B has hydraulics (not all did), I wouldn’t use 10w30 motor oil.
1951 B
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77845 |
I use 8 quarts of UTF in the trans / hydraulic/ bevel gear box , and 80-90 gear lube in the final drive drop box pan on each side.. Takes less than a quart on each side.
BenGiBoy
Mine just has the PTO, no hydraulics.
Okay. Thanks all! Ben
'39 Model B
Lars(wi)
Orange Level Access Joined: 14 Sep 2009 Location: Permian Basin Points: 6658 |
keep in mind that SAE 20 weight, if i'm not mistaken is non-detergent
CTuckerNWIL
Nothing but Universal Transdraulic Fluid in my tractors.
Bill Long
Orange Level Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
When we sold them newin the 30's to 50's we used NON DETERGENT SAE 20 wt oil. It worked fine. However, I have heard good reports on the UTF type oils.
In the final drives we used 140 but again there are better lubricants out there now. Take good care of my favorite. Good Luck! Bill Long
BenGiBoy
Okay. I'll put something in it then, it's probably not super particular i'm getting the idea. I'll let ya'll know what I use...
Thanks all! Ben
'39 Model B
Gary
Orange Level Access Joined: 13 Sep 2009 Location: Peterborough,On Points: 5173 |
Just don't use a Detergent Oil in the Hydraulic. Apparently it will foam up. Gary |
BenGiBoy
That makes sense, hydraulic oil probably has anti-foam agents or something in it.
'39 Model B
