D17 Series IV & rollover plow
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series IV & rollover plow
    Posted: 16 Oct 2019 at 7:42pm
Assuming I will never find a two bottom AC 3pt rollover plow, how would the AC D17 series IV hand other makes?  I would imagine they are going to be heavier than an AC version.  Seeme to me you need min 50 hp to handle a two bottom rollover and the D17 is almost but not quite there at 47 on the drawbar..any experience with this?
Edited by TomYaz - 16 Oct 2019 at 7:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2019 at 8:13pm
I think Eldon had a rollover plow on a 170 /175 . Same 3pt setup as the ser4 . I think it was an Oliver
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2019 at 9:16pm
Brother had a 3 bottom AC roll over plow on his series 4 D 17. Worked well but did have to add weight to the front end. Den
Own 5 720 garden tractors with associated equipment,1 620 garden tractor, 4 wheel 20
2-5015, 5020 and associated equipment and 2 electric forklifts.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2019 at 10:48pm
My brother pulls a 3 bottom with his D15 diesel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2019 at 11:43am
Thanks..so a two bottom rollover is not out of the question it appears....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2019 at 12:28pm
WD-45's handled 2-bottom rollover plows. D-17's would handle three.,
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2019 at 2:25pm
Our D 15 diesel came with a snap coupler 3 bottom plow . Never pulled it with any success though . Thanks
tbird View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbird Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2019 at 4:54pm
Pulled a 2 bottom roll over with my wd in clay without a problem
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2019 at 6:11pm
My father had a CA with a 2 bottom AC rollover. Had side weights on it but plowed without a problem. Still have the side weights somewhere in the barn.
Edited by Stan R - 17 Oct 2019 at 6:13pm
ICTRCTR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ICTRCTR Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2019 at 9:27pm
  I have a 3 btm & a 2 btm roll over plows both are 3pt and are allis. call  4o2 223 5339 located in se Nebraska.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2019 at 9:46pm
Yes I run OLIVER 3-18's with my 175D, it actually works better than on my 6080. You will need extra weight up front, tho. I put my 8' Bush Hog on my D17 SIV Diesel and the front end was waving in the air...gas would be worse, no doubt.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2019 at 6:21am
Thanks guys,
My soil is heavy clay. Sounds like a 3 bottom may work. IC I will ring you up.
Tom
This page was generated in 0.065 seconds.
