D17 lift capacity |
dink
Bronze Level Joined: 14 Mar 2015 Location: Illinois Points: 28 |
Posted: 11 Aug 2019 at 1:27pm |
I'm trying to find the 3 point arm lift capacity of a D17. I am looking at a no till drill that weighs around 2500lbs.
frnkeore
Silver Level Joined: 07 May 2019 Location: Southern Oregon Points: 362 |
What series is you D17?
Frank
1959 D17 Series I #24001+, '59 D14 '55 & '59 Ford 850 & 861 Ferguson TO 35 Deluxe, Oliver 70 and 5 more. |
orangereborn
Orange Level Joined: 12 Sep 2009 Location: NW WI Points: 1403 |
dink
Orange Level Access Joined: 12 Sep 2009 Points: 19583 |
Thanks(1)
So, you have an after-market 3-point hitch, which won't lift as much as a factory 3-point on a series 4 tractor.
dink
john(MI)
Thanks(1)
If you have a Saginaw three point, it will lift as much as a factory. It mounts the same as a factory does, and it's as heavy duty as a factory one, possibly more. As far as lift capacity, I don't think a D17 will lift that much weight. If it does, you'll need to add some weight to the front end. There is no information on that number in my data book.
Edited by john(MI) - 11 Aug 2019 at 8:47pm |
Gary Burnett
Orange Level Access Joined: 11 Sep 2009 Location: Virginia Points: 2854 |
Thanks(1)
A drill sets back of the tractor right much,I can't see a D17handling one that weighs 2500lb.
DaveKamp
Thanks(1)
I responded in the other thread... I've had some 2000+ lb loads close to the face on my 3-point... and based on how it handled that load, a 2500lb grain drill would not be manageable on a Series 1, even with lots of counterweight. It would be able to lift it, but you would be upon it's limits so much, that you would NOT be able to operate it in the field with any efficiency.
Thanks(1)
The heaviest mounted plow A-C made was the 80 series 4 bottom, which weighed 1400 lbs. Your 2500 lb drill might be closer to the rear wheels, which would help, but I still think it would take an S4 factory 3 point and a lot of front end weights to get that much lift accomplished.
