1952 CA PTO seal
dekrenn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dekrenn Quote  Post ReplyReply Direct Link To This Post Topic: 1952 CA PTO seal
    Posted: 16 Jul 2019 at 4:49pm
I have a 1952 CA that is leaking oil at the PTO.  Seams to be coming from the seal.  Is this easy to replace or is there more than what I see from the outside?
Thanks....
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2019 at 7:56pm
Review this post:   CA Rebuild
Gerald has posted a link to the service manual for the G, B, C, and CA in his reply. Look at page 45 in the CA section and it gives you a breakdown of what is there, You just need to drain the oil, then remove the bolt on cover the seal is in to change the seal. You may need a speedi sleeve for the shaft if the seal has worn a groove in it.
You may want to save a copy of the manual for your future use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dekrenn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2019 at 9:34pm
Thanks a lot!
