D17 series IV hydraulic pump help.
etcv97 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote etcv97 Quote  Post ReplyReply Direct Link To This Post Topic: D17 series IV hydraulic pump help.
    Posted: 21 Jun 2019 at 10:44pm
Resealing a pump on our 64 d17, and put new plates and seal kit in it from agco, the pump will not turn freely once the bolts are even snug, it has a lot of resistance.
Is this how they are supposed to be or is something wrong? The plates are the only thing different. It had a new seal kit put in last year and they failed due to the plates having grooves in them from the old seals.
1958 D17, got a lot more just need to find out what years they are.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2019 at 10:55pm
Usually takes a pair of pliers to turn one with new seals. You have oil on the gears and plates, right ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote etcv97 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2019 at 11:21pm
It has a film of oil but not much. We had to use a large Allen wrench in the drive gear and it was pretty hard to turn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2019 at 7:34am
If it was mine, I would be disassembling the pump so I could use a micrometer to measure the thickness of the gears and the body. There has to be a minimal amount of clearance between the gears and plates for it to work properly, but there HAS to be clearance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote etcv97 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2019 at 9:22am
The new plates are thicker than the originals by .010 each everything else is the same as it was before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2019 at 10:04am
Doesn't that pump use rubber backup seals behind wear plates? That  would make the thickness of the plate a non issue
Post Options Post Options   Thanks (0) Thanks(0)   Quote etcv97 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2019 at 2:12pm
It has rubber and plastic seals that come in the kit I assume the plastic goes in the groove first followed by the rubber going against the plates.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2019 at 2:54pm
Rubber Goes In First
Post Options Post Options   Thanks (0) Thanks(0)   Quote etcv97 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2019 at 4:39pm
So you are saying the blue plastic goes against the plates unlike the originals that were rubber with a formed wire?
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2019 at 4:49pm
yes . blue against the plates. the pump will turn hard when together but should turn with pliers
Post Options Post Options   Thanks (0) Thanks(0)   Quote etcv97 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2019 at 4:55pm
I thought the rubber was to seal it like the old ones how does the plastic seal?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2019 at 5:11pm
oil pressure from the gears, moves through the hole in the wear plate and pushes the wear plate against the gears making a tight seal. the blue plastic can take the oil pressure to make the seal. the rubber would just blow out. the old seal used the metal to hold the rubber in place, but it wore in to the wear plates.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2019 at 5:23pm
A suggestion; beings you have the pump removed & disassembled.
Take some time and remove the sump casting, screen and magnetic donut-shaped filings "trap"  You'd be surprised at what can accumulate over the years.
It can be a bear to get off, so you'll need a set of gaskets for sure, and possibly a new screen if the old one is damaged in any way.  And some Permatex #2
This page was generated in 0.211 seconds.
