WD-45 Fan/Waterpump
Prairie Homer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Prairie Homer Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 Fan/Waterpump
    Posted: 09 May 2019 at 6:16pm
How do I pull the Fan/adjustment hat from my WD-45 waterpump? The bolts are off but the fan/pully seems seized to the pump shaft.
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 6:40pm
 With a board using a hammer gently tap the board when it is up against the back side of the pulley, should come loose after a couple of hits, if not rotate the pulley and hit it again.
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 7:41pm
Could use a bit of heat to help
