Need help trouble shooting ONAN |
coggonobrien
Orange Level Access Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1806 |
Posted: 05 May 2019 at 4:58pm |
I'm getting any fire even though there is juice to the ignition box. When turning the motor over I do not see the rocker moving in the ignition box. Where should I start?
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4638 |
Sounds like you may need a new ignition pin that opens the points. The are made of carbon fiber I believe and they do wear. That’s one of the reasons the points have to adjusted in addition to the wear of the points itself. I replaced mine as well as the guide.
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4768 |
So, as I asked on another thread about these points, Does anyone know of a good electronic conversion? Even good quality points and condensors have been hard to get. Is that pushrod a readily available part? Cummins sure jacked all the prices of these parts years ago!
ShaunE
Bronze Level Access Joined: 03 May 2015 Location: Wisconsin Points: 51 |
David, If your points plunger has worn to the point it won't open the points any longer then you can take an old Buss Fuse & break the glass out of it & place the metal end over the points plunger to hopefully give you enough length to reset the point gap. I know it sounds crazy but I read this on the smoke stack forum, tried it & it worked. You will still need to eventually purchase a new points plunger or convert to Electronic Ignition. |
AC720Man
Ed the Onan parts are crazy pricey for sure. When I went through mine 7 years ago I could not find an electronic ignition. There was a post on here about a year ago that a member said they installed one. I should have searched before I responded to see if I could find it. I would like to rebuild one of my Onan’s but finding a .10 over kit has eluded me. They sure are proud of their parts for sure. Hopefully someone will post the electronic ignition again.
AC720Man
Jacks small engines and SLI have the Onan parts if you haven’t already checked. Imagine Steve also, he may also know of a electronic ignition.
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3286 |
i heard that some one at sandy lake was working on an eletronic ignition conversion kit for the cckb and ccka
Brad in WA
Bronze Level Access Joined: 29 Sep 2009 Location: Lynden,WA Points: 191 |
Check with Sandy Lake on the electronic ignition, pretty sure they have them.
coggonobrien
Sandy lake does have the conversion but the price is ridiculous. I thought it was 500 or 600. Whatever it was I was high enough that I would rather do a motor swap if it came to it.
injpumpEd
WOW! My luck, I'd spend 500 bucks on electronic conversion, then chuck a rod the next time I used it lmao! Looks like I can just keep replacing points a bunch of times for that much! ouch!
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4414 |
Having trouble shooting at an ONAN? 😼 Maybe you need a bigger target 🎯 after what experience I’ve had with ONANs, I lump them in with Tecumsehs and 2 cycle dogtriots👎👎👎
coggonobrien
does anybody have a part # for the points plunger?
injpumpEd
seeing this reminded me that I have a parts book in my 720 binder. Looks like it's 160-0262, looks like it is several parts.
Dnoym N. S. Can.
Orange Level Access Joined: 03 Oct 2009 Points: 544 |
Rod in MN
Silver Level Joined: 16 Sep 2009 Location: Rice MN Points: 290 |
HI Coggonobrien,
What Model of Onan Engine do you have it would be something like CCK,CCKA , CCKB, B43G,P218G The last to are John Deere models Rod in MN
coggonobrien
ccka
