mud shields
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Topic: mud shields
    Posted: 06 Mar 2019 at 8:56am
     Did anyone see or buy from ebay the items listed as NOS WD-45 front mud shields? About a week ago. I never heard of such an item before. The ad said they were "super rare" but showed a page from a parts book listing the part numbers. Kind of wish I'd bid more for them. Went for $81.97 plus freight. Has anyone on here ever had or seen such an item. I can't figure out how or to what they were attached.
Gary(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2019 at 9:29am
ac hunter. When I was a kid at home in the 1950's my dad had the scrapers on a WD and a C. I do not know how they were attached to the WD but the C had two ubolts that held them to front pedestal. They are kinda rare. I still have that C I drove as a kid. It has the scrapers on it and don't know how many people has tried to buy them. Have a good day. Gary
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2019 at 9:38am
All WD45 tractors (not on wide fronts) with factory power steering had them, I have two WD45's with them and right now two in the shop WD45 Diesel with them on too. not "super rare" just not on all WD45 tractors. held on with two spring loaded pins.
Gas and Diesel shields are not the same.
They are on power steering narrow front or single fronts to keep the mod/rocks out of crankshaft pulley. And yes I know where they went, no they are not for-sale. I didn't buy them. Please don't ask who got them, I can't tell on himWink.
Edited by Don(MO) - 06 Mar 2019 at 9:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2019 at 10:16am
Is this what you're talking about Don? My 45 is a 1954, so the PS was added and it never had these things.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2019 at 10:51am
Well that's not it, that's a lower radiator shield for WC/WD tractors with a mounted corn picker.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2019 at 11:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2019 at 11:21am
So they would be kinda like the mud shield under the D17 narrow front, but in 2 pieces?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2019 at 11:36am
     Those are the ones. So do they bolt on under the frame rails to keep mud away from the pulley on the end of the crankshaft and radiator?  You would be getting into some serious mud if that is the case.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2019 at 1:11pm
The one you show above is the right one for WD/WD45, it's just the one piece, they not two pieces. They are held on with two spring loaded flat sided pins that go through the slots like in the pic above and there are two punched tabs in the L shaped side in the pic you can't see that fit's in the two holes in the front engine mount holes that are used to hold a wide front end back brace on. The WD45 shield are a piece of cake to take down, just pull down and turn the two spring-loaded flat pins a 1/4 turn then drop the front part down and the pull the shield forward a 1" or 2" and out it comes.Smile
Edited by Don(MO) - 06 Mar 2019 at 1:15pm
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2019 at 3:07pm
So, it appears the seller thought they came as a set of two......I think the purchaser got a real deal.........two for the price of one.
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2019 at 7:08pm
This is the shield for the 45 Diesel that Don has mentioned...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2019 at 1:17pm
Thanks Chad I don't have pics of the shields. It's funny the ease of removing the shield off a WD45 gas tractor compared to removing one off the same tractor with the Diesel engine is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2019 at 1:20pm
Charlie that picker shield hard to find too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2019 at 9:52pm
My 45 was narrow frt w/ps. It still has one of those clips in the left frame rail. I put a wide under it.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2019 at 10:58pm
i always learn somthing new from you guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2019 at 11:09pm
I'd still like to see pics of it on the tractor as I've never seen one either.  I'm still scratching my head trying to figure it all out!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 4:55pm
Here you go Ted, That's pics of two dif.  WD45 gas tractors top two pics are of the same tractor. It was hard to take the shots under there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 5:27pm
If you ever ran a "naked" narrow front in the goo-ball mud,you'd understand the need for the mud shield. You can destroy a fan belt sooner than you think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2019 at 12:05pm
Just a better pic of the clips that hold the shield on the gas models....
This page was generated in 2.307 seconds.
